Liked 269 Times in 99 Posts
With my last engine we did a test to see if there was a big problem with my EFI setup and took off the tune port and put on a 350 manifold, not the best but good and a dyno Q-Jet and picked up 20 HP. Nothing else changed.
Liked 319 Times in 68 Posts
Joe, on Bryan's 305 the carbureted combo made 20 more horsepower than the F.I. and made power at a higher rpm. The F.I. combo makes more torque and has a flatter torque curve. run at the same weight the carb is faster.
Lee Valentine 1661 STK |
Guys, the carb guys aren't going to believe you by they think there is magic in that ECU. LOL
Btw, that small TB is restrictor. It flows less air that a QJet. My friends with 350"s & carbs often run well past 8500 in the lights, some way past. Dave Layer, when I ordered my heads, told me a 350" would all done by 8200 RPM, of course he was correct. Smart man.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 07-24-2013 at 07:18 PM. |
Liked 121 Times in 11 Posts
Barry rumor has it that neither of us is the fastest H/SA in D-1 let alone at Indy. I am going to take a pass been a rough year. My ego can't take losing hahahaha. My money is on you if you go in H/SA. That is why I am looking for a soft EFI combo.
Joe DeMarzo 1317 STK |
Liked 4 Times in 1 Post
I'm gonna take a stab at this. The Third Gen Camaros mentioned above have a manifold with relatively long runners, which will make more power down low, and perhaps explains why you observed a harder launch.
Q-Jet manifold that I assume Frank and Lee refer to have much shorter runners, and should make peak power at a higher RPM, which probably accounts for the higher peak HP observed. If the comparison was made with identical manifolds and the same total area throttle body/throttle blades, and fuel curves both optimized to whatever extent possible, I'll argue that the FI has superior atomization, and should make a little more power at every increment.
Tony Curcio 1860 STK |
[QUOTE=
If the comparison was made with identical manifolds and the same total area throttle body/throttle blades, and fuel curves both optimized to whatever extent possible, I'll argue that the FI has superior atomization, and should make a little more power at every increment.[/QUOTE] Let's take an look at a ringer in the Mopar DragPak engine with the tall single plane and throttle body on top. Easily replaced with a carb. If the throttle body was flowed, a really good Holley was assembled to match, have a feeling that there would be little to nothing. Don't think there is any way to compare EFI to Carb in a stocker apples to apples. If you look at the potential of the combination with it's HP rating then you have something to study. Not being a dedicated student it appears to be a new car or a slow car.
#7 | |
Liked 13 Times in 9 Posts
[QUOTE= That is why I am looking for a soft EFI combo.[/QUOTE]
Get a new Camaro or Mustang. Or call Billy.
Liked 39 Times in 10 Posts
Hot Rod mag did a comparison test about a year or so ago using an FI LS1. They swapped on the Edelbrock LS1 4-barrel manifold/carb and made more peak HP in every test. The torque curve was a lot peakier however. Of course the EFI system is infintely more tunable, so there's that... The results really surprised me, I thought the FI would be more efficient by design?
Some really interesting results and good things that make you think here... which is why I replied to this post to start with.
I will have to try to find the Hot Rod article. Same type of apples to apples that Michael is talking about. My question, is the throttle body truely the same cfm as the carb? Just hard to understand how on same cfm of air flow, the carb would make more HP, with the tuning ability of the FI cylinder to cylinder. NOT arguing, just trying to understand. But then again, I have raced for years, and racing in the summer in TX... ![]() Ken |
