Old 06-30-2013, 08:25 PM   #1
Default Re: 1965 Impala BBC I/S
That was the X - Frame 1958 - 1964 Chevy/BOP/Caddy
Yes the 58 got the X-frame as GM began installing heavier engines.
GM always boosted about the ride quality.
The Lower Links were angled toward the X-Frame and no Panhard Bar.
This frame required 2 - short drive shafts and a Center Link prone to snapping. (I know that so well)
65 - 76 went to H - Frame 4 Link set up with Panhard Bar.
Spring set on the Lower Suspension Link.
Used much heavier U-joints.
Then 77 up to 96 D / B Body used the earlier 1964 & up Chevelle/BOP Mid sized car H-Frame set up.
Upper Control Arms were angled eliminating the Panhard Bar.
Spring mounted on the Axle.
The 91-96 used a 8.5inch 10bolt that has a history of being very rugged.
Someone said you can put a larger 8.75 12 bolt Carrier in it.
Never understood why they were not put in Camaro/FB?
The Drive shaft rarely had any issues.
U-Joints lasted the life of the car regardless of abuse.
For racing gears just needed a balancing and the weight tab removed from the Yoke...and still keeping the original U-joints.
On my 1995 Impala SS purchased a Dick Miller Frame Connector for the upper and lower control arms.
Think he makes it for the Plus Sized cars too.
Hope this helps..
D
For the record:
65-70 full size ..3 or 4 arm (right or both uppers). Panhard bar, and springs on trailing arms.
71-76 ..Std 4 trailing arm, springs on housing , except for f/s wagons ,which were leaf springs.
77-96 Std 4 trailing arms ....7.5 rear standard in these cars... even in f/s Chevy wagons.
Old 07-01-2013, 05:33 AM   #2
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
For the record:
ahhh, so i'm NOT crazy (even though my mother had me tested )
Old 07-01-2013, 04:41 PM   #3
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
For the record:
91-96 all got the 8.5 inch Rear, at least the 5.7 liter.
Have them on both my 94 Caprice Wagon an 95 Impala SS
The Camaro/FB got the little ones
D
Old 07-01-2013, 06:37 PM   #4
D
Nope....you didn't say 5.7 cars, which may be true.
305's came with 7.5's ...I had one...with a 2.56
That gives you about a 1.80 gear in OD..That's how it got 28 mpg @70 with the a/c on.
Old 07-02-2013, 06:39 AM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Yac -
My parents had an '86 Caprice 305 that came with a 2.29:1 7.5 rear axle. I drove them to the east coast to see my brother when that car was relatively new and it got 25-26 mpg @ 70 with A/C on consistently using an electronic Qjet carb! Amazing considering the aerodynamics of that body.
Old 07-02-2013, 12:25 PM   #6
Dan Fahey
Dan Fahey's Avatar
Yeah I can see them with the smaller rear.
But have not seen one with the 4.3L LT-1 but does not mean it was not installed.
My 94 Caprice Wagon has a set of 2.56's and has touched 24mpg best loaded with family. Mostly in the 23.5 range.
The Impala SS originally had 3.08's and get a best of 23.75mpg. But consistently 23.23mpg.
When our Impala B-Body guys added the 6sp.
Some installed 4.10's and reported 25 - 26mpg.
Other TOPIC
HEY WILL...
Please send me the Photo's of your Frame.
danfahey@dansources.com
Name:	1994 ImpalaSS Wagon.jpg
