Old 08-27-2007, 09:01 AM   #1
Bobby Zlatkin
Bobby Zlatkin's Avatar
Default Turbo-Action E-Shift Controller
We all know by now that what ever NHRA says is law. Makes no difference whether the call is correct or incorrect. Seems they would rather take it to the grave than admit they were wrong.
This first became obvious to me in the early to mid 1960's when Bill (Farmer) Dismuke bounced everyone that went through teardown with a Chevrolet '097' green strip solid lifter cam (270 & 283HP). Seems somewhere between GM & NHRA the wrong specs. got published. Even though a cam was gotten over the parts counter and run "out-of-the-tube", it was bounced. Dismuke, after a while at least, knew these guys weren't cheating. but wanted to make a point, ruling with blinders on. A lot of innocent racers (if there is such a thing) got hurt by the call that he knew was wrong.
The latest Turbo-Action Cheetah E-Shift for stockers ad in the Dragster shows that this exact same mentality still exists at the NHRA.
NHRA drew their line in the sand on this issue saying that all cars with fuel injection can use the E-Shift controller to automaticly shift and cars that came with carburetors, can not. Makes no difference if the cars original computers controlled the shifts or not.
The example used in the Turbo-Action ad is 1985 Camaro 305 fuel injection can use the E-Shift controller and 1985 Camaro carburetor can not. Neither car came from the factory with electronic shift.
Why would the fuel injection car be allowed an electronic shift and not the carbureted car? What happened to a level playing field?
Another example of how narrow minded NHRA can be.
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 08-27-2007, 12:08 PM   #2
Jeff Teuton
Liked 325 Times in 50 Posts
Default Re: Turbo-Action E-Shift Controller
Bobby, you are right. When I ran the trucks, we used a 904, but it would have been ok to have the e-shift. I think there are tech meetings @ Indy. Now might be the time to send an email to tech, Len, or someone so that item might be addressed. I assume all the EFI GM cars already have this inasmuch as this was the original design. Does sorta seem to be a funny item.
Old 08-27-2007, 12:50 PM   #3
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
The E-Shift controller is an outside controller, which in my opinion does not have a place in Stock. If those computer-controlled cars can program their factory computer to handle the shifts, -=shrug=-, fine. Otherwise, pull the shifter yourself. It's more fun, anyhoo. If you want your automatic transmission to shift automatically, hands-free, then don't put a manual valve body in it. ;-)
They're fine for other classes where air/electric shifters are permitted. Sounds like a great product, like all of Turbo Action's stuff. This one's just not for Stock, in my opinion.
Just my $.02,
Old 08-27-2007, 05:57 PM   #4
Woodro Josey
Liked 3 Times in 1 Post
Who with a stick uses a clutch to shift by.
Mylin tell me what shifts the late model cars?
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 08-27-2007, 06:13 PM   #5
Chad Rhodes
either everyone gets them or no one gets them. thats the only fair way to do it
Chad Rhodes 2113 I/SA
Old 08-27-2007, 06:16 PM   #6
Michael Beard
>> As for the safety factor, if you are scared to pull the shifter with the front end hung up
If you're steering with any number of hands with the wheels in the air, umm... you're not doing anything. Pro Stockers drive with one hand. Where does an automatic shifter enter in as a safety device?
While we're talking safety, how about fire jackets mandatory for all drivers running 11.49-quicker?
Old 08-27-2007, 06:25 PM   #7
Woodro Josey
Michael, what is wrong with the Jacket Rule?
Old 08-27-2007, 10:40 PM   #8
LouisJeffery
Talking Re: Turbo-Action E-Shift Controller
Why hasn't anyone answered Woodro's question about stick cars?
LouisJeffery is offline   Reply With Quote
Old 08-27-2007, 11:03 PM   #9
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
I was wondering the same thing about the handshift guys. My ears been listening to drag cars for many years and the stickshift cars I hear today don't always sound like what was normal years ago.....Maybe my ears are shot
Rich Biebel
S/C 1479
Stock 147R
Old 08-27-2007, 11:14 PM   #10
LouisJeffery
Smile Re: Turbo-Action E-Shift Controller
This situation could be cured without changing the rule. Just add to the rule that if a electronic transmission is used it must be a production electronic transmission. No adding electronic shift solenoids to non electronic transmissions. Nobody ever produced a production electronic shift 3 speed automatic. So NO 200,904,C-4. Unless you want to shift manually.
