Liked 10 Times in 10 Posts
The '1968' Battle of the mid-sized body Dealership Musclecars.
Plymouth 383 Road Runner * Engine............383/335 HP * Car Weight....#3424 lbs. * Wt/Hp.............10.22 Released on September 12, 1967 A 'bare-bones' Belvedere, with a some 'novelty emblems' and a Power-Bulge Hood with 'non-functional' air-induction vents. An improved 'steady-and-durable' 383 now rated at 335 HP, thanks to the addition of the Camshaft and Valve Springs from the 440 Super Commando, as well as an Oil-Pan Windage Tray. For good measure, the 'wind-swept design' Exhaust Maniolds from the 440 Super Commando (with 2 1/2" Header-Outlets} were added, to improve exhaust flow. Not necessarily designed for the Drag Strip { NHRA E/S or E/SA Class }, but more for the young Street-Racer ie; ''Budget-Minded Econo-Racer" who could only afford $3000 for a performance car. Last edited by Paul Ceasrine; 06-12-2013 at 02:21 PM. |
1968 Pontiac GTO
Engine...............400/350 HP {Standard} Car Weight.......#3504 lbs. Wt/Hp................10.01 Released in September 1967 A 'dressed' up version of the 'Original Musclecar', with a few more bells and whistles, as well as a new design. Available with the 'Standard' 400/350 HP, generally a good street performer. Also to be classed in NHRA E/S or E/SA, but this version was more of a 'Gentleman's Musclecar'. |
Jack,
When they both were introduced in the early Fall of 1967, The Road Runner was only available as a 'Pillared-Coupe'. The GTO was available in both the 'Hardtop' or 'Convertible'. After January 1968 (mid-year addition) the Road Runner was available in the Hardtop Model as well. |
1968 Plymouth Road Runner
Pillared Coupe with the 383/335 HP 'H-Code' Base Cost {October 1967}...........$2896 Included; * 4-Speed Manual * 8 3/4" Rear-End, with 3.23 Gears {Open Rear} Options * Sure-Grip.............................................. .......$39 * Torque-Flite Automatic Transmission.....$196 The 'first' Road Runner 'Print Ad' {September 1967 - Hot Rod Magazine} ![]() 1968 Pontiac GTO Hardtop with the 400/350 HP Base Cost..........$3101 Included; * 4-Speed Manual {Wide-Ratio} * 3.23 Gears {Open-Rear} Options * Safe-T-Track Differential.................$42 * Turbo-Hydramatic Automatic.......$236 ![]() Last edited by Paul Ceasrine; 06-17-2013 at 09:10 AM. |
