Old 08-21-2007, 02:47 PM   #26
JCQuinn
Liked 2 Times in 1 Post
Default Re: 7.5 lb class for GT
Originally Posted by Lynn A McCarty View Post
My software includes drag coefficient, frontal square area, ride height, it was all included. (cant get a number unless you enter all the numbers) You pick the vehicle from the data base for the frontal square area or you can do it yourself. Then you measure the height of the car off the ground. Yes we all know these are approximations,, and aerodynamics is a factor of many, but these big ET losses simply arent reality. (One guy told me 5 tenths)
On the other hand, how much is Ram Air, hood clearance, and wheel base worth? You gotta consider everything not cherry pick. If you want to try one I will run the software for you. I dont have all the body styles, but I have a pretty good list of the common ones.
Just think about it, you can scrub 5mph off at the end and it simply doesnt affect ET that much.
Lynn
Lynn is this something you do commercially or just for your own edification? If you don't mind I am curious how an 85 Mustang would stack up against the Colbalts.
JCQuinn is offline   Reply With Quote
