I have a BG 2 port regulator that wont adjust, it goes to 15lb and i cant get it down to 8 or so... is there a fix for it? OR is it worth messing with? THanks
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
Liked 510 Times in 117 Posts
Take the regulator and throw it in the garbage. Years ago I ordered a BG regulator and it did the same thing. Summit replaced it and it did the same thing. Sent it back again. Third time, same thing.
68 Chevy11 327 F/S |
Barry Grant was good at marketing. Not so good in the quality control department...
Jeff Lee 7494 D/S '70 AMX |
Thanks Guys...i will not even mess with it... I will put a Holley Volumax on it.. itll work! ITs on my '62 Cat, bracket car...i bought it used , a couple years ago...thought i'd try it... oops!
Liked 541 Times in 112 Posts
I've had one on my car for years, never had a problem (knock on wood). They do require a special inlet fitting that is ported on the regulator side.
Jim Kaekel 3836 STK |
I may have the wrong fitting...im not sure what its supposed to look like...the one i was using, looked like a normal fitting...
It's a special 1/2" NPT fitting that is ported on the NPT side, larger I.D. than the AN side. of the fitting. Here's the text directly from the BG catalog right next to the 2-Port Plus Regulator-
NOTE: Be sure to use a 1/2" NPT adapter fitting on the regulator's inlet that has a minimum I.D. of .530". Fittings with a smaller I.D. on the pipe thread side will interfere with the inlet side function of the regulator. If you don't have this special fitting, you could easily enlarge the inlet side.
When I got my regulator from BG I got the proper fittings for it and the results were the same. Pressure would not hold. Switched to Magnafuel with never a problem.
The fitting that i used, was same size, all the way through... The one that i used on my Volumax reg, was tapered, where it screwed into the reg. That's probably the fitting that i need... i may try it again , when i have time...
