Liked 4 Times in 4 Posts
Does anyone have some old Nitro Joe stats, to see if anyone has ever run this combo before, and if so, how fast they got?
Liked 53 Times in 25 Posts
Sent a PM to Nitro Joe maybe he can help you out.
Dennis P Chapman 1904 STK NHRA National Record Holder Car Owner. |
#3 | |
No....only in a Regal , about 30 years ago
Thanks Mark. I was curious.
I should add to this project, that not only am I doing it on a budget, except for the small shop attached to my house (which is only big enough to do engine and trans work inside), the rest of this car is being built in a carport, in Montana. Mother Nature decided my weekend should be spent indoors, 35mph winds and rain/snow are no fun to work in. So, if I can make this happen with no shop and this budget, ANYONE can! |
#5 | |
Not much to report, except I came a across an MSD 6-BTM and 2-step off craigslist for $160, and since this thing can shift itself, I sold my ratchet shifter for $100. It's still snowing, so I am at a mild standstill.
That was your best investment so far...
Well I got a little done today before Mother Nature revolted, the engine compartment is ready for the pressure washer and some rattle can flat black. I threw in a couple newer pics, how about that patina? I kinda wanna keep it...
I also made a run to the wrecking yard, and scored a couple pieces I need, which lead to my cheap tips of the day: Need a high output coil? Check out a TFI coil on a fuel injected 5.0 Ford. They're 40,000 volts and fairly compact. I got one for $5 Need a cheap GM mini starter? Try a 94-98 GM pickup 350, 96-98 S-10 or Blazer 4.3, or 97-98 Astro. Compact, gear-reduction, and in my case, $10! I also threw in a pic of my 95 Cougar electric fan, fits a GM radiator perfectly. |
I don't see where you mentioned the transmission. Did I miss it?
For now its the original TH350, non lockup, with a rebuild and B&M shift kit. I plan on having it shift itself around 5500 with governor tweaking. The converter is a 10". Hughes part #GM40, which should hopefully stall around 3400 or so.
I am all ears for suggestions though... |
