Originally Posted by Jeff Teuton
No, I can't run 10.39 in E like the Findel's can in Minnesota. They got the record. I can't get there. Maybe if I move some bolt holes though. Hmmmmmm Correction: James Findel holds the E/SA at 10.58 and Andrew Hill holds the D/SA record at 10.39; both old cars. Hmmmmmm something amis here. Those combos need hp. F/SA is at a minimum though and I can probably run the 11.35 minimum cause of the good air. With the bolt holes removed. I bet if Andrew Hill took the bolt holes out, he could run 9.99 in D/SA.
All the bolt holes are already gone, everything's just held in place with superglue.
