Old 02-26-2013, 09:49 AM   #1
Jeff Teuton
Liked 325 Times in 50 Posts
Default Re: Record Setting time in Baytown?
Well, it's getting better, low Friday 38, high 60 bright sunshine, 37 or Sat, high 60, need to set a record, start driving now for all you northern folks. Hell, I bet a bolt hole or a no bolt hole hemi SS/AH could set a record here.
Jeff Teuton 4022 STK
Old 02-26-2013, 11:28 PM   #2
Brett C
Liked 1,018 Times in 217 Posts
I guess that means that we'll see a stable of those Southland Mopars all apart this weekend!
Old 02-27-2013, 10:03 AM   #3
Jeff Teuton
No, I can't run 10.39 in E like the Findel's can in Minnesota. They got the record. I can't get there. Maybe if I move some bolt holes though. Hmmmmmm Correction: James Findel holds the E/SA at 10.58 and Andrew Hill holds the D/SA record at 10.39; both old cars. Hmmmmmm something amis here. Those combos need hp. F/SA is at a minimum though and I can probably run the 11.35 minimum cause of the good air. With the bolt holes removed. I bet if Andrew Hill took the bolt holes out, he could run 9.99 in D/SA.
Old 02-27-2013, 11:45 AM   #4
Andrew Hill
Andrew Hill's Avatar
Liked 170 Times in 38 Posts
All the bolt holes are already gone, everything's just held in place with superglue.
3207 D/SA, C/ED
Andrew Hill is offline   Reply With Quote
Old 02-27-2013, 01:39 PM   #5
Ed Wright
Ed Wright's Avatar
Just hook up the other two barrels, Jeff. LOL!
Ed Wright 4156 SS/JA
Old 02-27-2013, 10:07 PM   #6
Jeff Teuton
The bolt holes on my heads are hollow, and the air is routed into the throttle body after it gets a dose of blue bottle.
Old 02-28-2013, 04:41 AM   #7
Andrew Hill
I thought the beer was by the can, not the bottle?
3207 D/SA, C/ED
