Old 02-21-2013, 02:48 PM   #1
Toby Lang
Liked 2 Times in 1 Post
Default Re: Question for JEFF FOSTER
I find it very conspicuous that Jeff Foster hasn't replied to this thread yet. I'm pretty sure he's seen this thread. His last activity on the forum was on the 18th and I started this thread on the 17th.
Maybe it's because he knows it's really not the photographers that are causing the problem and doesn't want to admit there is a problem with the timing system.
I've heard a photographer has tried numerous times to replicate the problem and couldn't do it. I guess it's much easier to just blame the photographers.
How about it, Jeff? How about a reply to this thread? Or better yet, how about some testing while you have all the photographers at Phoenix? Surely you can find a little time before or after the racing is done to test this. I'm sure the photographers would be happy to help clear their names.
Old 02-22-2013, 02:58 PM   #2
Dave Kommel
Default Re: Question for Jeff Foster and Dave Kommel
NHRA has now "fixed" the problem by banning all flash photography at all times and anywhere from the water box to the 225' photographers limit.
Dave Kommel
Dave Kommel is offline   Reply With Quote
Old 02-22-2013, 03:09 PM   #3
Toby Lang
I wonder what they will ban next when it happens again.
Old 02-22-2013, 03:13 PM   #4
novassdude
Liked 136 Times in 49 Posts
Good question Toby, and we know it will happen again. Probably no more video of the run by your crew. Then no more chrome wheels, then no chrome at all on the car.
As we all know it is not an issue with the timing system!!!!!!!!!!!!!!!!!!
novassdude is offline   Reply With Quote
Old 02-22-2013, 04:02 PM   #5
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Old 02-22-2013, 06:44 PM   #6
CycloneFE
CycloneFE's Avatar
Liked 2 Times in 2 Posts
Well I don't have the answer either, but I will say that flashes can do weird things. I have taken hundreds of pic at the track and this is the only time it has ever happened and I have pics of the same car when I did not have a flash that were just fine. I used a medium grade Vivatar always set to manual mode. The panels on the car WERE reflective tape. Why it came out this way is still a mystery to me, even 30 years later.
Name:	Crying TIme Mustang reflection.jpg
Steve Jackson
Old 02-22-2013, 09:01 PM   #7
chevy620
Banned
The only reason I have not heard yet...........and I feel it is THE REAL ANSWER, is DeFrank's car moved. I do not mean forward or rearward roll; I mean when his top bulb came on he went to the chip and it "shook the front tires" enough to let the infra-red beam to get to the receiver cell. I owned a track and watched A LOT of races on the starting line.
If Jimmy staged really shallow all was good...then when it hit the chip or just went to the mat...it could have caused enough tire movement to bite him.
He was lucky...he got a rerun. Why didn't Mike Cotten get one? It looked like he was .05 on the tree but it went red....must have been a camera or a spaceship sending infra-red signals.
WOW! I would have been so mad if I was Cotten I wouldn't have to worry about pre-entries, I would probably be banned after that "hose-job" he took. Win the WinterNationals and then get the news your opponent "didn't really red light"!!!
Sad day for Compulink if that can happen; maybe nobody has ever "really red-lighted"?? That would change some big race final rounds wouldn't it.
I owned a Compulink System. They were state of the art, but they have been surpassed by the drivers and cars the last 10 years.
I think it is time for a timing equipment overhaul, at least get it as accurate as some of the cell phones and data recorders being used by racers today.
C'mon Jeff; we know you are reading this. Let's hear the official reason on how a camera can start the tree.
Jok
chevy620 is offline   Reply With Quote
Old 02-22-2013, 09:45 PM   #8
Michael Beard
Once AGAIN....!!!
1) One updated version of the system includes a provision that locks out the pre-stage and stage bulbs from coming back on once the system thinks the car has left the beams (ie., stage light out), until the computer is reset. This prevents the pre-stage and stage lights from flickering when the rear tire goes passes through the starting line.
2) This red light phenomenon has occured at multiple tracks. One instance included a car that was footbraked: staged at a low rpm, then was brought up on the converter and was there for several seconds. The car was *solidly* staged with absolutely zero posibility of it having backed out of the beams.
3) The above incident, as well as several others that we have seen all show the red light displaying BEFORE the pre-stage and stage lights go out. This is a critical point that everyone continues to completely ignore.
4) If a car did in fact rock back out of the beams, you would see the stage light and pre-stage go out simultaneously due to the stage bulb lockout system (see #1 above) along with the red light being displayed. The only case in which the red light should be displayed BEFORE the stage light going out would be in the case of a deep stage foul in the classes that do not permit it.
YES, it is still possible to have a red-light from rocking out of the beams on systems not utilizing StageLock, and in fact it just happened in Super Comp last weekend at Gainesville. The multiple incidents we have been discussing are demonstrably different situations.
Old 02-22-2013, 10:30 PM   #9
Greg Reimer 7376
Liked 705 Times in 219 Posts
What are photographers doing there anyways? There's too many bodies around that starting line anyway at that race, and although we can't change history, we can eliminate that possibility real quickly. It's also a safety issue. Drive line failure on the line could eject parts, somebody that close could get hit, there's also the distraction factor.Good photos can happen from other locations, why do they have to do that right there?
Old 02-23-2013, 06:26 AM   #10
Toby Lang
This isn't that big of a deal. The video camera just catches the stage light as it's going out and the red light as it's coming on. Here are just a few examples I found. There are plenty more.
2011 Winternationals, incandescent stage bulbs:
2012 Winternationals, LED stage bulbs:
I have a question for you, Michael, since you seem pretty well versed in the stage-lock system. In Mr. Cotten's meeting with Jeff Foster and Mike Rice they told him: "It is not impossible to have a roll back red light with the stage lock on. But, it requires a motion of at least of a half inch to the rear."
My question to you is: How does the system know if you are a half inch behind the beam? I don't think the computer can tell how far you are behind the beam unless the infrared sensor can tell from how much infrared light it's receiving from the reflector. If not, I would think you could roll back until you turned the pre-stage light off.
And this begs the question, if the infrared sensor can tell how much infrared light it receives, why can't it differentiate between infrared light and a flash from a photographers camera?
