Old 02-20-2013, 07:41 AM   #1
FrankChastain
Location: Trussville, Alabama-Originally from Vidalia,GA
Default Re: Question for Jeff Foster and Dave Kommel
Look at the O'Reilly sign at the right hand top corner on the sign. Then looking at the passenger side of the car about where the parking light is. According to this the car hasn't moved in any of the four pictures...Just an observation....
Originally Posted by Toby Lang View Post
I just found out there is a video of this and being the video guy that I am I checked it out and here's what I found:
Here's the frame right before the red light comes on:
Here's the next frame when the red light starts to come on:
Here's the next frame when the red light comes on fully:
And here's the next frame after the one above:
It's hard to tell by just looking at the photos, but in the last frame you can see the reflection of the flash off of the left front corner of the car.
You need to download each picture and scroll through them and it's easy to see. I just use Windows Picture and Fax Viewer and use the right arrow to go to the next picture.
If I were a betting man, which I am, I would bet the camera that took the picture has the capability to trigger external flashes. And to trigger the external flashes the camera uses infrared.
I don't know how external flashes work, but it makes sense that you would have to send out a signal from the camera to the external flashes before the actual flash happens so the flashes are in sync.
The video has a frame rate of 30 frames per second. Which means each frame is .033 seconds apart.
So I believe my hypothesis was correct in my post yesterday.
FrankChastain is offline   Reply With Quote
Old 02-20-2013, 10:31 AM   #2
Dale Hulquist
Liked 351 Times in 76 Posts
Thumbs up Re: Question for Jeff Foster and Dave Kommel
Toby, if i'm ever involved in a close race (which is not likely) i'm going to hire you for your (DSI) Drag Scene Investigation, very through. Good job counselor.
Dale Hulquist is offline   Reply With Quote
Old 02-20-2013, 12:28 PM   #3
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
If you step through frame by frame on the Mason incident video you can clearly see the camera flashes, and they do not coincide with the red light coming on. The red light comes on *after* the camera flashes, and the the pre-stage and stage bulbs go out AFTER the red light comes on.
In the Brand incident there does not appear to be any camera flashes involved, and you're dealing with a footbrake car that staged solidly and then came up against the converter, so you are definitely not dealing with an issue of rocking back out of the beams. Once again, the red light comes on BEFORE the pre-stage and stage lights go out.
This issue has also occured at a track in the east in bracket racing, and we've seen similar things happen in the Pro categories.
Old 02-20-2013, 02:03 PM   #4
Jody Lang
Liked 89 Times in 28 Posts
[QUOTE=Michael Beard;370036]If you step through frame by frame on the Mason incident video you can clearly see the camera flashes, and they do not coincide with the red light coming on. The red light comes on *after* the camera flashes, and the the pre-stage and stage bulbs go out AFTER the red light comes on.
If you're going frame by frame wouldn't the red light have to come on after the camera flash? I wouldn't expect it to come on during the flash.
Jody Lang is offline   Reply With Quote
Old 02-20-2013, 03:29 PM   #5
Rory McNeil
Liked 1,103 Times in 301 Posts
Good point. The camera is stationary, on the ground, so any movement of DeFranks car should be obvious.
NHRA 6390 STK
M/S 85 Mustang
Old 02-20-2013, 04:02 PM   #6
Michael Beard
Step through the Mason video. The red light comes on 8 frames after the first flash, and 5 frames after the second flash. That's not just "after", that's a *significant* delay. Also, it's been noted that each frame represents a fair amount of time. The timing system is dealing in thousandths of a second, so I would imagine that it IF the flash was the culprit, it is very possible that its results could appear in the same frame, if not the very next frame. 5 frames? Don't think so. Again, it also appears that there aren't any cameras involved in Brand's incident. Camera flashes may just be a coincidence.
None of it explains why the red light comes on BEFORE the pre-stage and stage lights go out in each instance.
A poster on DRR mentioned they had this problem frequently at their home track:
At my home track, this very same issue kept showing up in the right hand lane, DURING eliminations only. The track at first blamed it on the driver rolling forwards or backwards out of the beams. Then looked for cobwebs, ants, sun reflection etc. Then after much logical, thoughtful incise and concise gentlemanly discussions, accompanied by arm waving, four letter words, threats of violence, promises to never set foot on the grounds again, and other civilized, illegal actions, somehow an answer was found. it was discovered this only happened during eliminations, only in the right lane, it was random, not a common occurence. A lady that used to run the compu-link system for the track, suggested that they turn OFF auto start during eliminations, and see if the problem went away. IT DID!!
We had a different issue at the bracket finals at Rockingham a couple of years ago. We had numerous errant runs. I was announcing and noted the anomolies before racers even got to the tower to complain. We stopped and replaced one or more photocells on the starting line (that had just been replaced a week or two before). Had problems with the Stage beam hanging so bad it wouldn't go out at all. We turned off Stagelock, and had no more problems. Weird things happen. Maybe we think they shouldn't happen, and we maybe we think the solutions shouldn't be the solutions. Doesn't change the facts.
The most bizarre thing I've ever seen is having R/T's, all incremental times and mph matching other timeslips and making sense, but having the finish ET being off by about two tenths of a second, and the MOV likewise showing about two tenths despite the cars being separated by thousandths. It happened multiple times at the same event, with different cars. How or why it happened, I have no idea, but the only plausible explanation I could come up with was that somehow the finish line sensor "missed" the front wheel, and was triggered by the back tires. A car length was roughly the amount of ET that was "missing".
Old 02-20-2013, 04:13 PM   #7
Toby Lang
Liked 2 Times in 1 Post
Like I said, I don't know much about external flashes. Cameras also use infrared for autofocusing. The DeFrank red light could be a case of the camera autofocusing before taking the photo. I don't know if it would take that long to fire an external flash.
As for the Mason red light, there are also three other photographers on that side of the rail. Maybe one of their cameras caused it by autofocusing.
It looks the photographer has to be in the right spot and take the picture at the right time for this to happen. It sure looks like there is some infrared coming from somewhere that is causing this. There definitely needs to be some testing to see what is going on so it doesn't happen again. They need to to get all the photographers together at some point during an event and have them take pictures at different angles to see if they can consistently cause this. Maybe there needs to be a car in the beams for it to happen. If they can't get it to happen then it must be the timing equipment.
As for the Brand red light, the footage doesn't show if there is a photographer on the rail or not. It could be caused by autofocusing as well.
Old 02-20-2013, 04:23 PM   #8
Dave Kommel
Modern DSLR's do not use infared for focusing.
Dave Kommel
Dave Kommel is offline   Reply With Quote
Old 02-20-2013, 05:25 PM   #9
Toby Lang
Do all photographers at the track use modern DSLRs?
And what about external flashes? How long of a delay is there after pressing the shutter and the flashes going off? Is this delay adjustable?
It's possible to have the internal flash off and still be sending a signal to the external flashes, right?
Old 02-20-2013, 06:18 PM   #10
Jody Lang
Does anyone know if this has happened in the super gas/comp classes?
