Old 02-19-2013, 05:33 PM   #1
FINESPLINE
FINESPLINE's Avatar
Default Re: Red Light Answer
Maybe far fetched but food for thought. Has this problem only surfaced since the beginning of LED prestage and stage lights. Regular bulbs have a filament that that takes time to cool off and can be relit and not not be noticed by the human eye. Not so with a LED . much faster on/off. Example - LED brake lights and why they use them today. Could be a tie in with the electronics ?
FINESPLINE is offline   Reply With Quote
Old 02-20-2013, 10:16 AM   #2
Jody Lang
Liked 89 Times in 28 Posts
The one that happened 2 years ago was the old style stage lights.
Jody Lang is offline   Reply With Quote
Old 02-20-2013, 04:38 PM   #3
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
The Defrank car has smaller tires on the front. And the way these cars are built today they sit very low to the ground so the pre-stage and staging beam have to be fairly low so the front end does not trip it. (not sure what the standard height is). With that in mind when shallow staging there is less circumference of the tire blocking the beam. When setting the trans brake most feel that your car won't and can't move. When staging you set the trans brake, during that time you are waiting to release the button. If that car with small tire moves .030 or .050 or .100 for what ever reason, more back up pressure applied than forward, wind, etc ... do you think anyone would be able to actually see that movement, but that may be all it takes to light the red light by allowing enough of the beam to make contact to the outside cell.
So what you have is a 900 hp car that is relying on a trans brake to keep it from moving in either direction ..
just a crazy thought ...
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
Old 02-20-2013, 05:11 PM   #4
Liked 5,121 Times in 1,952 Posts
Right, Chuck. ...and on top of that, the car shakes from being on the rev limiter.
Old 02-20-2013, 05:28 PM   #5
Mike Brogniez
Makes more sense to me than a camera flash....every posibilities should be examined and a solution found to eliminate this type of red eye.
Old 02-20-2013, 05:50 PM   #6
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Ground clearance is required to be a minimum of 3". Stage beams are roughly 1-5/8". Yes, transbrake cars can back out of the beams. It happened in Super Comp at Gainesville last weekend, and it was recognized for what it was. That is a different animal. Again, all of these videos of similar incidents show the red-light coming on BEFORE the pre-stage and stage lights go out. Additionally, one of the examples of this phenomenon was with a footbrake car that staged at a low rpm and then came up on the converter, which results in the car moving forward slightly in the beams. While red lights are possible by rocking back out of the beams is possible on systems not utilizing Stagelock, this is demonstrably a separate issue.
Old 02-20-2013, 07:52 PM   #7
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
It is and was common practice for many people running doorcars with trans brakes to apply your line loc along with the trans brake. It will help to stop any movement once the brake is set and your staged.
The Defranks could not win as much as they have unless they had all their ducks in a row as the saying goes.
In 1970 at Atco in the first round of stock my partner was redlighted for this exact scenario.....slight movement backwards but it was a stick car and the starting line probably had a slight dip in it....and we did use a line lock to try and hold the car.....it didnt prevent that one......
Rich Biebel
S/C 1479
Stock 147R
Old 02-21-2013, 02:23 AM   #8
cody pollage
Also whos not to say there wasn't a bug or an insect in the timing cell that moved into the beam and made the stage light come on. I've seen that happen before more than once. What I'm saying is maybe DeFrank was never really staged. The insect moves in front of the beam, turns the stage light on, and when it moves, the stage light goes out and goes red because there is nothing in the stage beam now. It has personally happened to me, and I've seen it happen to some other people, and no it hasn't been at just NHRA tracks, and it hasn't been with just the Compulink system
cody pollage is offline   Reply With Quote
