Old 02-06-2013, 01:59 PM   #1
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: Best floor jacks
Rob,
I am glad, My wife got it for me for Christmas a few years ago, and now it looks like the Harbor Freight Aluminum ones are made better, than that expensive POS.
As for the Jack that I use at the track, it is the Harbor Freight 1.5 ton with a 3/4" piece of plywood with side rails to not allow the jack to roll off the plywood when not on solid ground, The plywood is not much bigger than the jack. Also use the plywood to place jack stands on, to lift the rear of car in the trailer.This prevents the jack stands from damaging the coin floor. Multipurpose tool!
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 02-06-2013, 08:15 PM   #2
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
i'll tell ya right now, if it has cast parts, don't buy it....i'll post a pick of mine sometime...plus don't buy one with the single wide roller on the front, they don't turn worth a sh.........
Old 02-07-2013, 10:01 AM   #3
Signman
Liked 269 Times in 99 Posts
Have the HF 2 ton lightweight which is OK but they have a 3 ton which looks much more well designed.
http://www.harborfreight.com/aluminu...ons-68052.html
This motorcycle jack is great for transmissions when working with jack stands on the floor!!!
http://www.harborfreight.com/lightwe...ift-94715.html
Old 02-07-2013, 08:03 PM   #4
Weekend Racer
Do the HF aliminium jack ,harder to pump than more common steel jack?
Weekend Racer is offline   Reply With Quote
