Old 01-29-2013, 02:46 PM   #91
Tom Nolan
Liked 64 Times in 11 Posts
Default Re: Suspension Notice for S/SS by NHRA
Broken strut rod photo!
Tom Nolan is offline   Reply With Quote
Old 01-31-2013, 12:04 AM   #92
69Cobra
Liked 2 Times in 2 Posts
WOW!!! From what I've heard people think that going to the urethane bushings is the answer to try and cut down on the deflection but this is what you end up with.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 01-31-2013, 12:23 AM   #93
Ed Wright
Ed Wright's Avatar
Scary!
Ed Wright 4156 SS/JA
Old 01-31-2013, 02:25 AM   #94
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
The urethane bushing WILL break the strut rod. Something needs to flex and you don't want it to be a 45 year old strut.
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 01-31-2013, 11:55 AM   #95
Frank Bialas
Frank Bialas's Avatar
Liked 23 Times in 13 Posts
Years back I had terrible bump-steer issues, so bad that I would change 3 idler arms a season until I started eliminating rubber. I know first hand what it's like to change lanes when applying the brakes on top end. the strut design is OK for the local streets and highways but not the harsh abuse/travel the front suspension takes in one of these high flying stockers or super stockers. I have bent steel struts, I've also broken an inner tie rod end due to the severe bump-steer and worst of all trying to do an alignment or maintain your settings becomes a joke especially the caster and toe. I swore I would never install rubber again, but learned real quick that the harder urethane or synthetic bushings life span was unpredictable and or shorter. Currently my upper and lower control arms have solid bushings and I was going to have Mike Roth from MR2 bush my Idler arm, it just seems that the more rubber eliminated the better it feels.When one of these bushings pops the wheel does rub the inner fender, when this happens @ 130 mph plus it suddenly becomes an amusement park ride, except you hope it's over real soon, and hopefully you don't make contact with anything or anyone in the other lane.
Frank Bialas 1570 STK
Frank Bialas is online now   Reply With Quote
Old 01-31-2013, 03:08 PM   #96
FINESPLINE
FINESPLINE's Avatar
Gentlemen, I have read this thread and all the posts over and over again. I am bracket racer that has no dog in this hunt but will tell you that the car that I own and drive ( sometimes on the street ) has some of the be.st offerings the aftermarket can supply. I say this because the the car was assembled using NHRA stocker rules. It would not take much to make it a legal stocker. What the NHRA has done is an abomination as far as safety is concerned. To say in a letter that this will happen because of skinny front tires, you seriously have to question whether any thought or research was given to that answer. I would be embarrased to give that answer and you should embarrased that you as members of the NHRA pay to have have this person representing you. Has the the NHRA done any research , any R& D or any A B A comparison to come out with this rule. Safety in this sport is job 1. I have no idea what these people are thinking and am glad they don't represent me. There are too many very knowledgeable people in the sport to call upon to settle this problem. I normally don't ramble on like this but I have to say I am with the racers completely on this. SAFETY above all.
FINESPLINE is offline   Reply With Quote
Old 01-31-2013, 03:57 PM   #97
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Quote of the day. You can't fix stupid!
The seats are one thing, suspension and wheel stands and being able to safely stop is no doubt a safety issue. It seems that the people with cars with this type of suspension, your requests seem to be falling on deaf ears or stupid people in control of safety.
Good luck guys
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 02-01-2013, 11:24 AM   #98
acme383
Frank, What did they bush your idler with? Aluminum bushing? What kind of difference did it make? (not to get too far off subject)>
acme383 is offline   Reply With Quote
Old 02-01-2013, 05:17 PM   #99
Dyno
Dyno's Avatar
Liked 685 Times in 204 Posts
Angry Re: Suspension Notice for S/SS by NHRA
SECTION 11: SUPER STOCK, BRAKES AND SUSPENSION: 3, SUSPENSION, Front (Page 5) (2/4/2013)
Must retain complete stock front-suspension system as produced by manufacturer for body used. Lift kits/travel limiters permitted. Sway bar optional. Aftermarket tie rods strut rods with heim joints spherical bearings permitted. Electric shocks prohibited. See General Regulations 3:4.
Just posted
Old 02-01-2013, 05:50 PM   #100
SSDA Hemi
SSDA Hemi's Avatar
Liked 451 Times in 77 Posts
Originally Posted by dyno View Post
section 11: Super stock, brakes and suspension: 3, suspension, front (page 5) (2/4/2013)
must retain complete stock front-suspension system as produced by manufacturer for body used. Lift kits/travel limiters permitted. Sway bar optional. Aftermarket tie rods strut rods with heim joints spherical bearings permitted. Electric shocks prohibited. See general regulations 3:4.
Just posted
Thanks Dan!
SSDA Hemi is offline   Reply With Quote
