Liked 882 Times in 236 Posts
I'd just like to say thank you to Matt and Rich.
They just recently refurbished my Onan 7500 Quiet Diesel generator for my coach, and the price and service was outstanding. They installed a new inverter section and replaced all the hoses and the belt,and a whole lot more for a fraction of what a new generator would have cost. I highly recomend R&J Controls to anyone needing to have their gen repaired or to buy a new unit. Thanks guys!
Looking for input regarding Martin Diesel and Next Gen diesel generators? Pros and cons for both would be appreciated. They are going to be used in an ambulance as a back up power source to an inverter. We are currently using Martin Diesel and our ambulance builder is recommending Next Gen for some new ambulances we are having built. Thanks in advance.
Joe Martens AA/Stock 3969 |
Liked 544 Times in 213 Posts
Joe I am not familiar with either brand name generator you mentioned. So I could not give you any info on one....
Onan is by far the most common generator we get in for service or see for repairs. I have worked on many of them that were installed in emergency response type vehicles. Diesels usually.... We have occasionally seen PowerTechs and I have worked on quite a few of those as well. Tom thanks for the recommendation. See you soon.....Rich
Liked 216 Times in 77 Posts
Cummins Onan RV QD 10000
Is there anywhere I could find out how much fuel they should be using? And how many hours should they be run before servicing (oil, filters ect)? Thanks |
Sponsor
Oil and filter is 250 hours, fuel and air filters at 500 hrs.
My experience is that might be a bit too much, I go 200 and 400 respectively. Fuel consumption will vary depending on how much load is on the engine, so the factory guide lists this: No load = .11 GPH (gallons per hour) 1/2 load = .48 GPH Full load = 1.01 GPH Hope that helps....
Matt Schurman |
Thank You.
#7 | |
Liked 275 Times in 76 Posts
Rob,
Does the generator sound like it has a load on it? Do you have access to a amp meter to measure the load at each circuit breaker? It sounds like there is a load on it from something else, other than what you have described. You could turn off circuit breakers one at a time and listen for the generator to unload, if something is drawing from it. I can run my A/C and everything in the trailer for close to 20hrs continuously on 15 gallons. I have a Onan Marquis Gold 7500. Good Luck Sean
Liked 62 Times in 19 Posts
Great thread/THANKS guys.Just curious what the life of a generator is,before it needs rebuilding /replacing.I just purchased a 2005 diesel pusher
with a Onan 7500 generator in it with about 1000 hrs.Never owned one before. |
Liked 24 Times in 17 Posts
With a Diesel Onan as long as you keep good oil changes with a quality oil and filter, give it plenty of fresh air/don't over heat it, chances are it may out live you. What hurts a gen set is sitting. They like to be run with a load.
I have seen a few with over 7500hrs personally. I don't think 15K would be out of the question if maintained. |
