Liked 2,486 Times in 697 Posts
Plaid is very popular in Boulder City! The different colors
hide all the extra dinners quite nicely! Sam is your car running very far under the NHRA index as of yet yet? We could not get ours to run very well over 5500 Rpm with the 2 Brl. and it screams 7000 plus with 4 Brl. when required. Maybe we just did not work on it long enough! Last edited by GTX JOHN; 01-11-2013 at 03:27 PM. |
#2 | |
Liked 43 Times in 9 Posts
I have to shift at 5400 5600. Stops pulling on the top end around 5600. The last 200-300 it's just going along for the ride.... The reduction to 182 is going to be worth 55 pounds and about 8 hundredths in the 1/4. Not nearly enough.
Sam Capizzi Jr. 1301 SS/AS 93 Dodge Daytona R/SA 73 Dodge Dart |
Liked 7,762 Times in 1,741 Posts
My 307 Chebby goes on it's nose at about 5700. So did my 6 cylinders.
The 318 2bbl motor has two major issues... Intake/carburetor and Valve clearance. Right now I'm using a cam at .050 and I have .025 clearance on the intake and .040 on the exhaust. If they would allow a 4 eyebrow 318 replacement piston, the combo would be good at 185 hp and would pull high rpm with more cam... Btw the 69 motor has .031 less clearance.
Sam Capizzi Jr. 1301 SS/AS 93 Dodge Daytona R/SA 73 Dodge Dart Last edited by Sam Capizzi Jr; 04-06-2014 at 09:02 PM. |
#5 | |
#6 | |
There are two intakes listed. (3698431 and 3698437) Ill have to try and find the one ending in 7. Heads. No flow bench 180psi cranking pressure Headers are 1.50 dia with 3' out. Not sure of length but has 12' collector
Sam Capizzi Jr. 1301 SS/AS 93 Dodge Daytona R/SA 73 Dodge Dart Last edited by Sam Capizzi Jr; 04-06-2014 at 09:03 PM. |
#7 | |
180 psi is OK but I'd like to see it around 200. I'd love to see that things reaction to about a .236/.240 on a 108(or even a 106) and with a lowgear TF it shouldn't need the cam advanced. 1.50 headers are right but I'd like to see it's reaction to a 2.5" collector.
#8 | |
Liked 5,125 Times in 1,953 Posts
#9 | |
#10 | |
That was a FWIW, Sam .That's all
