Old 01-06-2013, 12:03 PM   #1
SST159
Liked 20 Times in 16 Posts
Default Re: lOOKING FOR A LITTLE info ON SHOCKS,,,,,
Tom,
I too am looking to upgrade my front suspension this year. Frank showed me his set up and it really looked great along with his praise of the difference. I have a 70’ Camaro 10.90 and bracket car. When I 10.90 race, I limit the travel which is not a problem however when I bracket race all out, the car likes and needs the front end to come up and get the weight on the back tires. I currently use a tall 18” stock style springs ( a real bitch to install) with lots of stored energy and a respectable ride height and I use a Koni single adjustable SPA1 shock. I have ordered the tubular pro A-arms. I held off on the rack because it appears the only advantage for me would be weight and that is really not an issue at this time vs the work to install. Car weighs 2850, SBC and my fat azz. I would like to upgrade the shocks so I can adjust without taking them out of the car. As you most likely know the Koni requires removal to adjust. I was leaning toward the Strange single adjustable for stock spring set up. You mention some others. If you don’t mind what shock did you put in Franks car and do you have a recommendation? Thanks in advance for your help
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
Old 01-06-2013, 12:46 PM   #2
FG1090
Hey Drew, I have Strange single adjustable- # S5267. Just turn the knob and your done,had the same Konies they work but were hassel to change. Frank
FG1090 is offline   Reply With Quote
Old 01-06-2013, 01:10 PM   #3
SST159
Hey Frank,
Happy New Year to you and family.
Thanks for the info.
That is one of the shocks I am concidering.
Sounds like I may be in the right direction.
Drew Wonderly
SST 159
Old 01-06-2013, 01:24 PM   #4
FG1090
Happy New Year to you and yours Drew, You might want to give Lynns husband Tom a call at S&W racecars. I beleave they are having a sale on shocks this month,Good luck Frank
Old 01-06-2013, 02:32 PM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Drew ,the Strange singles will be fine on your car.
The big advantage of the rack is the elimination of bump steer.
this is not a huge problem on a car with stock suspension and limited travel, however it is an issue when allowing full travel.
You can correct the worst of the bump steer with a stock box by using heim ends and spacers to eliminate the stock tie rod ends.
Old 01-06-2013, 03:13 PM   #6
SST159
Frank,
Thanks I will give him a call.
Tom G,
Thanks for the advise. So there is some worth other than weight loss for my application by installing a rack. I may have header issues with that but have to wait until I put the motor back in and see. As always I and many others on this sight appreciate your experienced advise.
Drew Wonderly
SST 159
