Liked 58 Times in 18 Posts
The iron head uses the 1.72 exh. and the 401 alum. uses the 1.84 exh and also you run at 435hp. with the alum. head 425hp with the iron head. Thanks
Liked 30 Times in 17 Posts
I think the 401 alum head has a standard spec for all combinations it can be used on.
2195/1845 with a 103.3 chamber volume. Again, check the guide as always. |
The 401 head can be used on the 1969 427/430 ZL1 or L88 with 2.195 1.885 valve and 114.8cc camber also.there is a different HP. rating for the ZL1 and the L88, The ZL1 gets a bigger cam. If you use an original head casting (aliuminum) then there is a HP reduction.
Liked 5 Times in 3 Posts
Is there a horsepower penalty on the 396=375hp aluminum head engine if you use the original # 842 aluminum casting cylinder head or is the factored hp # for the 401 only ?
All the info you are asking for is in the classification guide. I don't think there is any difference on the 396 aluminum heads (new or old) but i could be wrong, just be careful if you call it a 402 that changes alot of small stuff.
We have a 427/425 with 401 heads. I would not build another one. If I get the chance, we'll be going to a set of 840 iron heads.
It is a good choice for a ZL-1, an L-88, or a Super Stock engine, and probably for a 396-375 or 402-375 in Stock.
Alan Roehrich 212A G/S |
Liked 69 Times in 9 Posts
I come from the land of Mopar where things seem a bit easier. That being said, I have to ask a few questions: How did NHRA wind up allowing the "401" aluminum head as a replacement head for the 427/425 iron head combo when it has a 1.845 exhaust valve? Didn't this combo originally come in only one version and that being a 1.725" valve in an iron head? There is also the question about how did NHRA arrive at the smaller chamber volume with the 401 head?
I would gladly stand corrected if any of my information is wrong. Inquiring minds would like to know. |
