Old 11-18-2012, 10:47 PM   #1
jmantle
Liked 172 Times in 81 Posts
Default Re: Aftermarket Cranks
Larry, I thought your post was right on before it disappeared.
I just read the whole stock section in the new 2013 rulebook about a dozen times, didn't want to miss anything. Found the following,
"Any special equipment export kit
(superchargers, dealer-installed options, etc.) automatically
disqualifies car."
That should take care of the group 19 AMC stuff.
"Lightening of crankshaft other than normal balance job prohibited."
How can turning a 2.437 journal down to 2.200 not be considered lightening the crank?
That's almost 2 lbs.
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
Old 11-19-2012, 12:42 AM   #2
SSDiv6
Liked 1,583 Times in 582 Posts
disqualifies car."
That should take care of the group 19 AMC stuff.[/QUOTE]
Before the parts were approved for the AMC, similar parts have been approved for Chevy, Ford and Mopar. Such as a Chevy 327 intake on 283 engines; Boss 351 using a Holley in lieu of the Motorcraft carburetor, 4BBL Hemi Nascar engine and more...
It has been going on for years; you can even buy an OEM light crankshaft from Crower for Chevy engines.
How did you calculate the weight loss when you do not have an idea of the material density removed? The crankshaft journal size change was dictated by the NHRA approved rod, the same as other engine makes such as the Oldsmobile small block and Chevy.
Old 11-19-2012, 01:08 AM   #3
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
So, let me get this clear in my head. "Stock Eliminator" allows aftermarket blocks, heads, rods, pistons, transmissions, clutches, rear ends, wheels, tires, suspension, shifters, unheard of cam durations. Lately added are valve job modifications roller rockers, now replacement seats and cranks. I find it hard to believe anyone would bitch about rod journal diameter while endorsing all the other "Safety" enhancements they now enjoy in "Stock"
Nothing even close to Stock with this class for a long time so might as well count the days until it's dead and you're a SS car like it or not.
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 11-19-2012, 01:40 PM   #4
jmantle
How did you calculate the weight loss when you do not have an idea of the material density removed? The crankshaft journal size change was dictated by the NHRA approved rod, the same as other engine makes such as the Oldsmobile small block and Chevy.[/QUOTE]
I fully acknowledge this stuff has been going on for years, just pointing out that some of us don't agree with it, especially in stock.
NHRA could have published separate approved rod lists for stock and SS and kept stock journal sizes in stock, never understood why they didn't.
As far as the weight of the cranks goes, steel weighs .283 lbs per cubic inch, ductile iron a little less depending on the grade.
Old 11-19-2012, 04:18 PM   #5
Liked 10,721 Times in 2,232 Posts
When you grind a 3.980 FE crank to 2.200 the crank is lighten about 1.625 pounds. I said pounds not ounces. The big gain is the change in polar moment of inertia. The weight reduction and where it occured is a big reason why the engine will accelerate faster. Multiply that times three if an automatic and four if its a stick and Ta-dah the car is faster.
And why does the 390/ 427get to use these rods?
Old 11-19-2012, 05:10 PM   #6
SSDiv6
Just 1.625 pounds?
I know of many that have removed a lot more by just using a different year crankshaft; there are OEM crankshafts for alter model car that have the crankpins and main journals drilled from the factory...and yes, the rules say no parts crossbreeding, however, how they can know?
As an example, you can get the "Stock Plus" GM forging crank fro Crower that is around 4 ~ 5 pounds lighter than OEM.
The rods were approved because at the time, it was the only rod that was close to the actual FE rod length. The same with the Oldsmobile small block rod; the first approved rods were 6" Chevy rods. It was the time of the advent of many new rod brands and makes, using forgings made in China.
Old 11-19-2012, 05:36 PM   #7
SSDiv6
Jim, when they approved the rods, it appears the approved them based on length and disregarded the journal size and to compensate, at a later date, they published minimum weights for all rotating components.
As regards to the approval and use of other parts and since you said you read the whole rule book, you omitted to quote the section that addresses such parts and components:
SUPERSEDED AND/OR REPLACEMENT PARTS
Superseded parts are restricted to cylinder heads, intake manifold, crankshaft, cylinder block, and transmission only when manufacturer lists such parts in its published parts book, notifies NHRA of said change, and change is accepted by NHRA.
