Old 07-20-2007, 10:46 AM   #1
Oldtimer
Default Re: Roller Rockers in Stock Elim?
What you have to understand is that this problem has always been around, 30 years ago with stock-stock rules we still had a rocker breakage problem with BBC and it did not matter if it was solid or hyd. Even with the Crane rockers they still break so this is not a pressure related problem of late. Bob Pagano
Bob Pagano L88BOB@aol.com
www.dyainc.org
4033 AA/SA
Oldtimer is offline   Reply With Quote
Old 07-20-2007, 11:38 AM   #2
ss wannabee
Liked 7 Times in 7 Posts
Wasn't aware of that Bob....need to get out more! What other engines are tough on rockers? Thought that the bigger pressures caused the problem....look at the pieces (and prep) needed to run the pressures! This is STOCK Eliminator???? Just my .02!
ss wannabee is offline   Reply With Quote
Old 07-20-2007, 12:21 PM   #3
SSDiv6
Liked 1,583 Times in 582 Posts
Buick, AMC and Oldsmobiles also have the same problem. It is not only spring pressure but the rocker geometry, specially when you run a dwell lobe camshaft.
Old 07-20-2007, 12:55 PM   #4
Oldtimer
Yes I am speaking about Stock BBC , I only ran SS two years with one of Jerry Steins Plymouths 71-72 and set the SS/EA record using stock rockers back in the day.
www.dyainc.org
4033 AA/SA
Old 07-20-2007, 02:30 PM   #5
Steve Calabro
Steve Calabro's Avatar
Liked 43 Times in 12 Posts
Send a message via AIM to Steve Calabro
You would have to go all the way back to stock, not just " a little" or move ahead. Remember " just put it in a little" you know what happened!
Steve Calabro 1199 STK, SS
Steve Calabro is offline   Reply With Quote
Old 07-20-2007, 03:26 PM   #6
Jeff Lee
Jeff Lee's Avatar
I have a friend that raced a brand new 340 Demon in H/S starting in 1972. It was killer fast for the day, ran 11.90's. He constantly broke rockers. And that's a shaft rocker in case you didn't know. He admitted to "cheating" and using Direct Connection rockers to cure that problem. Now you can run Isky "High Ductile Iron" adjustable replacement rockers even though 340's never came with anything similar except for the 340-6 (T/A & AAR only).
Vic G. (see how I avoided that difficult last name) who runs one of, if not the fastest D/SA cars in the country with his '71 429 SCJ Mustangs told me he breaks rockers (average) of every 2-3 runs. Myself, while racing Stock with my '70 AMX found the ONLY way to stop the breakage was careful lash adjustments (hand turn the engine over, lash each rocker not just "wiggle" test) on every other run. These rockers are just not designed for high-dwell cams as SSD6 pointed out.
What plays on deaf ears here is the fact your front runners spend a lot of money trying to alleviate this problem. And they do. Price out BBC rockers that are offered that don't break? Not to far off the price of Jesel "Sportsman" series shaft racker conversion! So purists, tell me why you want $1400 forged rods & $800 Schubeck lifters and all that other stuff in the reciprocating assembly that is offered but not this?
Jeff Lee 7494 D/S '70 AMX
Old 07-20-2007, 06:04 PM   #7
Liked 1,826 Times in 414 Posts
Pandora's Box has been opened, and the genie has been let out of the bottle. You'll never get what came out of the box back in, and you'll do good to get the genie back in the bottle. The BEST you can hope for is to reach some sort of plateau, and put up a fence to keep everyone from getting too close to the slippery slope.
(How about that for a full paragraph of cliches?)
Some of the racers, as well as NHRA, don't want to be bothered with an in depth tech inspection. So, the valve spring rule got opened up. Any valve spring so long as it is "stock appearing". Then the duration check was eliminated. Next thing you know, those valve springs pull the heads off of stock valves, so now you have one piece stainless valves (actually a good deal, saves the racer money in the long run). But then the killer valve springs combined with cheap cam cores and crappy motor oil starts killing lifters. So now you have ceramic foot lifters. Allowing a further escalation in valve spring pressure, and a serious increase in tappet velocity. Well, rocker arms were already breaking regularly, so the added load just pushed them further over the edge. Nothing in the valvetrain of a Stock Eliminator engine really resembles anything "stock" anymore.
The problem now is that roller rockers will cure the problem of rocker breakage, but ONLY the problem of rocker breakage. The next issue will be rocker stud breakage. There's a REASON they valve train people sell truck loads of shaft rocker conversions OR shaft rocker systems. Because studs break. Last year a lousy stud (actually it was a good ARP stud) broke and wiped out an entire engine for us. Allow roller rockers and the engines with shaft style
rockers gain a serious advantage again. Especially those with larger diameter lifters. Now, if you allow roller rockers and stud girdles (I doubt anyone will get NHRA to allow Jesel or T&D style conversions in Stock) that levels the field again, somewhat.
I doubt you'll ever get rid of killer valve springs and trick lifters. So maybe roller rockers and stud girdles are a reasonable concession in light of the other stuff that is there already, that will be there from now on.
I agree that the line needs to be drawn some where, and soon. However, realistically we cannot expect the line to be drawn back around 1990 and have everyone be forced to go back to there. Racers won't do it (at least most of them) and NHRA isn't going to do it, figuring it sells parts, and it's less tech for them.
It all comes down to being careful what you wish for.
