Go Back   CLASS RACER FORUM > Class Racer Tech > Garage Tech
Old 11-08-2012, 09:31 PM   #25
CycloneFE
CycloneFE's Avatar
Liked 2 Times in 2 Posts
Default Re: Shop, need suggestions
Originally Posted by Sean Marconette View Post
I am in the planning stages for a shop. What are the Pro's and Con's between an all steel building and a stick building? Door styles for overhead doors with wide spans. I am planning on housing a 48' trailer inside along with truck. Any help would be appreciated.
Thanks
Sean
Sean,
I am attaching some pics of a building I had built last year. It starts out as a 42 X 64 pole barn that becomes completely insulated in ceiling and walls. Along one wall(64 length) we put up a wall 9' from the side to have and area for office, mechanical, parts and a one stall garage (one car totally separated). This was studded and dry walled, with 8' ceilings but went up to 9' for the stall (7' door 2' rails). I had the white metal put on the shop area for easy clean up and to help everything be bright with light. The 9' area has the painted walls and wood trim like a stick built feel, but I can tell you that the insulation is so thick and works so well with the hot water heat running through the floor. I don't have total numbers, but I will bet I used less than 300 gal of propane last year and the heat was never less than 60 the whole time. Regarding doors, I put 2 10' X 20' one on each end so that drive thru is possible with my F-350 and a 28 tag. I wanted to go even longer and be able to unload the car from the trailer while inside, but I just didn't have the money for that. I hope this helps. Attached are some of the pics.
ID:	14350   Click image for larger version
ID:	14351   Click image for larger version
ID:	14353   Click image for larger version
ID:	14354   Click image for larger version
Steve Jackson
