Liked 52 Times in 17 Posts
Car is a '99 model year but rums as a ’98 with the LT1, with a flat hood that puts it in C,D and E or SS/JA - SS/KA. Change to a ram-air and it fits A,B,C,D,and E. A very versitile combination when a class is not been run. Custom ballast weights. It's factory dark blue with tan cloth interior, T-tops, Grant wheel, looks really nice.
Bud Rowe motor. Hedman headers MSD HSV coil and wires Holley crank trigger MSD distributor Complete Aeromotive fuel system, w/fuel filter and a strainer and nylon braided hoses (not rubber) CSR waterpump with a spare VDO playback Tach Holley annhilitator ignition with spare Holley 950 ECU, datalogging with O2 capability. My program Moroso circuit breaker switch panel Strong, switchable one wire alternator T-action converter gone through by Munsinger T-action shifter E-Shift installed but not currently used 200 metric trans, auto 1-2 shift, deep alum pan with baffle and extended p/u, prepped by Leo Glassbrenner (Remac) with some of his parts. Fuel cell and rear Optima battery, weight box Strange rear, 4.88 gears (recently renewed) with special drum brakes, (soft linings) Lamb front brakes with S10 master, the rod cannot fall out! S&W rear anti-roll bar Chromemoly tubular rear trailing arms QA1 alum. Adjustable shocks front and rear Centerline convo-pro MT fronts and radials Aftermarket rack Electric windows with side bars removed from doors New, custom black carpet with filled in floor Roll bar with swing out drivers side bar Several years ago the car was stripped to nothing and put back together that included: painting entire engine bay and underside gloss black, re-engineer all brackets and plumbing routes, complete color-coded re-wiring from front to back with all soldered joints and weather-pak connectors plus much more to make it a really neat package. This car is now 'ON SALE' for $25,500 Possible spare motor for sale with. Ph. 951 686 4230 __________________ Bernie Cunningham 7053 STK
Bernie Cunningham 7053 STK Last edited by Bernie Cunningham; 10-20-2012 at 12:02 AM. |
