Liked 1,948 Times in 589 Posts
I lost 2 engines due to oil filters collapsing. Now I would not run any throw away filters on the race car. I use the System One filter. Works great. Easy to clean. Easy to check for any problems in the engine. Do not use AC delco.
Mike Pearson 2485 SS |
Liked 1,034 Times in 368 Posts
For 8 years I made Aftermarket parts ,let me give you a little info.When I worked for United Technologies, I worked in a department that made the Ford Starter Solenoids ( the Black ones mounted on the inner fenders back then).We made 8800 of them a shift. There were 125 people working in that department. 120 women assemblers, 2 Maintenance men, and 3 Material Handlers. We had two lines running down through the department. One was a Ford line,the other the " Aftermarket " line. They were identical,sort of. All the new equipment, as it came in,was put on the Ford line.Then the used Ford pieces got taken over and put on the aftermarket line. The "test sets" that tested the finished parts were allowed to be set to a little lower standard on the aftermarket line. Not that we were suppose to be doing that, but we could get away with it . Ford kept too close a watch on us, All the rejected washers,plungers,coils, and springs etc and such that were unusable were taken off the Ford lines and put over on the aftermarket line.They would be ok to be used and would pass through the test sets, but for whatever reason they were inferior when compared to the Quality Control Print. Might just be a cosmetic thing.There IS a difference in the parts, but you can't tell it by the surface.They look identical, but their not
Jeff Niceswanger 3740 SS Last edited by Jeff Niceswanger; 10-06-2012 at 03:29 PM. |
Liked 482 Times in 159 Posts
I used to manage an AC Delco parts store for almost 10 years.(from 1994 - 2004). I also worked for jobber stores who sold Fram and Wix. I have personally had a Fram filter fail on my own Chevy V8 engine in my race car. I have never had any issues with an AC Delco oil filter and can't recall any customer issues either. Most recently I sold Wix mainly while I worked for Napa. (the last 7 years). The quality of Fram has definetely deteriorated once they started being distributed by big box stores. AC Delco used to be a decent filter and whether you bought it at a dealership or at Walmart is was the same filter. Wix seems to be a good product especially the Gold series. The Wix Racing series is a stout piece but it is not available for a whole lot of engines. Presently I use Wix gold series on my bracket race 600 hp Monza. I would not recommenend a Fram to anyone,at least not the entry level orange filter. A friend uses and loves the K&N filters on his low 10 second SB Chevy Camaro. On my daily driver Suburban I use AC Delco because I bought cases of them years ago, the PF1218 and have been satisfied. Ac Delco used to be mfd by Champion Labatories (Luberfiner) at least in Canada.(our filters were white in colour while the USA versions were blue).
Location: Trussville, Alabama-Originally from Vidalia,GA
Thanks guys for the comments. One reason I posted was I have noticed on my wife's TrailBlazer, straight line six, is sometimes you hear a nock or bump when you start the car up, not it the morning, but other times. As I understand there is a valve, in the filter, that keeps oil from draining out of the block so to have oil in the block for start ups. This is what I understand. The engine never did this until about 3 or 4 changes ago. I change the oil and filter every 3000 miles. Please correct me if wrong.....and again thanks..frankchastain
Please keep in mind this is a personal use car..... Last edited by FrankChastain; 10-07-2012 at 06:22 PM. Reason: put in in the block |
#5 | |
Each car manufacturer has a specific setting for the bypass valve based on the engine design. The worst offender of any oil filter is Fram; I stay away from them. The best built and design oil filters are Wix (NAPA brand), Baldwin, Hastings and Amsoil. |
Anti drain back valve,allegedly developed to correct the infamous cold piston slap in millions of GM 3.1 litres back in the early 1990's.
Liked 18 Times in 12 Posts
All I will use is Wix.
"Real Race Cars Have Tailgates" |
