#1 | |
Rick who taught you the calculation to figure it out? Am I missing the fact that it's a standard math equation? Or is it customized for this application? They used different math!! I have to wait 'til I get home and I will let you know his math. Bare with me. Thank you in advance. |
Sponsor
Straightliner,
Post up your times and the weather conditions and I will enter it into my software. It will tell you the ratio.
RacingRicki |
Liked 10 Times in 7 Posts
Yes , as RR said I can do the same for you.
I also would like to know what your stop rpm is, this is where the big ratio number may be coming from, again depending on your combo this number will be in the range of 3800 - 4400 the math is , a standard equation, ratio number x et change, however you must have the correct ratio. Then your next step is change in the air .... but we'll go one step at a time Rick
Rick Bailey 3439 SC Last edited by Rick Bailey; 09-15-2012 at 01:41 AM. |
Small problem, I didn't have a weather station yet. He was using his, I do have the DA from his notes.
Stop rpm- 4000, Ratio from notes is 8.7:1. I only have times using the stop. They were as follows: 10.993- 3400 DA- 1.860 timer 2 10.923- 2400 DA- 1.860 timer 2 10.877- 2400 DA- 1.460 timer 2 10.903- 2400 DA- 1.660 timer 2 His math was- 10.90-10.8777=.023. .023x8.7=2.00. Old timer 2 # of 1.460+.200=1.660 is new timer 2. Thanks guys I purchased a weather station and Crew chief Pro for next season. Brad |
I see there was a thousand ft differance in air, did that also end up in your ratio ?
Rick Bailey 3439 SC |
As far as I know it was .067 per 1000 feet.
