Old 09-14-2012, 09:07 AM   #1
Bob Verwold
Bob Verwold's Avatar
Default Re: Timer 2 caculation
Originally Posted by Straightliner View Post
I have been there and read all of it. He tells you how to figure out your ratio. I'm asking where it's posted about the math to figure out how much time needed to run a 10.90 something. Example I had timer 2 set at .6 and I ran a 10.75, now I want to run a 10.90. my car has a ratio of 8:1. What's the math?
I'm with Rick, I think your a tad high on your number. The best thing is seat time and good records.
You won't be able to slap up 10.900's all the time.
Do you have a good weather station ?
Bob Verwold is offline   Reply With Quote
Old 09-16-2012, 11:04 AM   #2
sc3912
Liked 6 Times in 1 Post
Could you define a "tad" high? Rick and I both run super comp and I know my ratio is around 2.8 to 1. I would consider 8 to 1 to be excessively high, but maybe in a heavier SST car the ratio will be higher considering the weight of the car and the HP of the car. What kind of ratio, and what kind of MPH do you run with your car? The car in question ran a 10.75 with only .6 in the timer 2 so it doesnt appear to have a lot of extra HP. Maybe it needs that much ratio to work. According to his posted numbers, the ratio he came up with appears to work. What does the car in question weigh and what does it run full out? I was looking at some of your posts in other topics and should ask you are you using the 3 speed or glide and are you shifting on time or by rpm?Also, what is your first timer?
Jeff Spierling
2007 Div. 3 S/C Champion
sc3912 is offline   Reply With Quote
Old 09-17-2012, 10:32 AM   #3
Straightliner
3500lbs, 3 speed turbo 400, so far it has gone 10.42 there is a bit more there but I need to get out to a test and tune day to find out.
540 bbc 700 hp crate engine. stop on @.300. Shifts into 2nd by time and into 3rd by rpm.
Straightliner is offline   Reply With Quote
