Old 09-10-2012, 03:21 PM   #121
Jason
Liked 8 Times in 5 Posts
Default Re: The damage recently done
Greg, not that I'm a FFFord guy but the original 50 681/2 CJs had aluminium intakes. The passenger cars didn't but, NHRA isn't going to start checking VIN#s to see which are which so they let all of the 68s have them. The 69s shouldn't have gotten the aluminium intakes.
Wrong Billy. The original 50 did not ALL have aluminum intakes. Only the cars that ran SS were allowed the aluminum intake along with flattop pistons and the .600 lift cam. If they had all come with aluminum intakes, they would have all been allowed to run that way since 1968.
Here is the website address:
www.428cobrajet.org/id-intake
Jason is offline   Reply With Quote
Old 09-10-2012, 03:25 PM   #122
Bart Kilraine
Liked 11 Times in 6 Posts
1968 =335 H.P.......2012 =383 H.P.....Not quite the same weight for C/SA !
Bart Kilraine is offline   Reply With Quote
Old 09-10-2012, 04:12 PM   #123
Greg Hill
Liked 279 Times in 68 Posts
One of those over rated cj's ran 9.98 at Earlville in A/SA. Pretty impressive.
Greg Hill 4171 STK
Old 09-10-2012, 04:53 PM   #124
Chris Kilraine
Chris Kilraine's Avatar
Liked 3 Times in 2 Posts
Greg, is that first 9 sec A/SA pass?.......??
Chris Kilraine is offline   Reply With Quote
Old 09-10-2012, 04:58 PM   #125
Billy Nees
Liked 7,912 Times in 1,755 Posts
Like I said, I'm not a FFFord guy. The fact still remains, NHRA isn't going to start checking VINs.
Jason, maybe you should bring this website up to the powers that be at NHRA!
Billy Nees 1188 STK, SS
Old 09-10-2012, 05:09 PM   #126
Chris Kilraine
Were those flat tops fly cut for the exhaust valves????
Old 09-10-2012, 05:35 PM   #127
CycloneFE
CycloneFE's Avatar
Liked 2 Times in 2 Posts
Jason provided the website, here is your answer.
Piston
(Cast Aluminum) C6AZ-6108-AY, 10.7:1 CR Forged, Dished/Eyebrows
11.0:1 CR
Steve Jackson
Old 09-10-2012, 07:06 PM   #128
jimi
Liked 21 Times in 8 Posts
Stock ended over 27 years ago anyway. Why all the bitching?
its 27 years already?
Old 09-10-2012, 10:33 PM   #129
Todd Hoven
Guest
Posts: n/a
As I remember the BIg Block Chevrolets received a crate motor intake that was much bigger and better than the stock one with no HP penalty. I think it was off of the 502 crate engine. Those cars are going 9.60's not bad as well. Not to much outrage about that.
Old 09-10-2012, 10:55 PM   #130
69Cobra
Not really when you consider that Lance has arguably the fastest CJ in the country by a few tenths and I'm sure its got every bit of Pro Stock technology that he can use to get it there. 9.984 on an 11.00 index is only 1.016 under. Now if I could get one to run a second under then I would be impressed but you're talking about a guy who's brother is arguably the best engine builder/tuner in NHRA Pro Stock. I think this separates Lance from the rest of us.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
