#1 | |
Autostart is not like firing a bullet that cannot be recalled once the trigger is pulled. You CAN stop the autostart system at any moment before the countdown actually starts, even in that short time period between the 4th bulb lighting and the countdown beginning. The point is that the starter has total control over when the race begins. He can allow autostart to run the show, or he can override it. Autostart protects the starter from being accused of manipulating the race results by being overly slow ("he burned my down") or quick ("he quick-tree'd me") on the tree. It makes the starters job easier and the races more fair. |
Liked 54 Times in 33 Posts
RJR
What are your credentials in order to make these statements? |
#3 | |
Same as yours. Just been hangin' around a long time, paying attention and, after a while, I've learned stuff. I hope that Jeff Foster from CompuLink will comment on this because if I'm wrong I want to know about it. |
how do you disarm the system you run once autostart is activated? there ain't no kill switch on that system
You don't.
You can arm AutoStart at any time the scoreboards are set for the next pair. But if anyone walks through or burnouts are done through the beams your all messed up.
The standard is to activate once you have 2 pre-stage lights that way everyone is set end the start line is clear and safe. You can de-activate (turn off) or over ride at any time till the first amber fires. To over ride in the situation as described 1 car cant make it to the line you leave it activated untill the good car gets staged then you turn off and imeditlly turn it back on as one motion of the switch. If you just turn it off the tower must reset the pair before anything can happen. Rick Stewarts arm movement is just that arm movement. He activates it at 2 pre-stage. If starter dose overide it is printed on the slip and tower log. If he waits to 4 lights is says that on the prints. In the GA situation Rick waited to till Greg was pre-staged acctually waited 2.5 extra seconds so GA had 9.5 seconds to stage. GAs team had a missunderstanding on what to do. They have all the time in the world to pre-stage if some one light 2 bulbs before you stage. But you need to be ready when you pre-stage to go the rest of the way in asap, at 3 lights you have 7 seconds in Pros or 10 seconds in Sportsman. |
Liked 104 Times in 35 Posts
As stated last night on NHRA @ Bristrol.. In the "PRO's" once all bulbs pre-stage and stage lights are lit. With autostart on they have .08 to 1.2 seconds before the tree starts.
It took GA 9.5 seconds to stage. The PRO can turn both lites on if they choose to do so. Nothing in rule book but we as sportman racers can not per rule book. Just what they said last nite at Bristrol
Bobby Brannon 4705 STK, SS |
