Old 08-07-2012, 05:05 PM   #1
Bob Verwold
Bob Verwold's Avatar
Default Re: Onan info
Originally Posted by schultz View Post
I have the same generator that had the exact same problem. A buddy of mine who works on Onans in the marine industry and has been to Onan training, told me this. Get a meter and check the Hz frequency at the outlet. It should be 63 Hz with no load 60 Hz with a load. If the generator goes up over 63 Hz it will shut itself off. I just had to adjust the throttle to get it into that range. Haven't had any trouble since. It's worth a try and won't cost anything.
Craig Schultz
S/ST 5909
That was my problem the whole time. An easy fix..............
Bob Verwold is offline   Reply With Quote
Old 08-08-2012, 04:14 PM   #2
Jeff Niceswanger
Liked 1,031 Times in 368 Posts
Thanks.....Will try this. Will let you know the verdict...Jeff
Jeff Niceswanger 3740 SS
