Doesn't NASCAR still use a "box" style steering?
Chad Rhodes 2113 I/SA |
Banned
Yes
Liked 10 Times in 6 Posts
Everyone knows why a few want aftermarket rack and pinion steering on older S/S cars. Its not about safety.......its all about less weight on the frontend.
Hang in there NHRA. Don't give in to the rantings of the few! If they want rack & pinion, tell them to build a FWD conversion for SS/GT and leave real S/S alone. |
#4 | |
![]() You should do your homework prior to making a non sense statement. The common Mopar aluminum manual steering box weight is around 19 pounds. A rack & pinion weight is around 14 pounds, not counting the mounting provisions. So, if you consider just the weight of both, is a 5 pound weight difference worth a 10th or more??? ![]() |
Nice try NWD.
Just incase you forgot, regular steering also consists of a heavy center link, 2 inner tie rod ends, 2 outer tie rod ends, tie rod sleeves, an idler arm with bracket, and a pitman arm. None of those are aluminum. And on makes other than Mopar, the steering box is much heavier. I stand by my original statement. Wanting aftermarket rack and pinion in place of the OEM steering box set up is only about saving weight...its not about safety. Last edited by Crew Chief; 05-11-2012 at 01:45 PM. |
#6 | |
If you are so smart and did some research, it is not a bolt-on deal for RWD cars that did not have it from the factory. Although you remove components like you said, it is not a bolt on deal. You need to add a frame to support and provisions which adds weight to the car. Just like the aftermarket seat thread, just because someone ask for a change, it does not mean that there is always an advantage. |
#7 | |
Its not about safety...its about lighter weight parts being allowed. |
