Old 05-04-2012, 02:35 PM   #19
SST159
Liked 20 Times in 16 Posts
Default Re: HELP PLEASE hood scoop and carberatour problems?????
I am curious as well.
I have been experienceing a similar problem ever since I changed my hood scoop last year on my door car. The old scoop I had sealed off with a pan and foam to the top of the scoop. The new scoop is much larger which I have not sealed off and lost at least 2 mph and have gained an occasional engine miss during the pass. EGT is showing lower than normal as well indicating a richer condition.
I have tried it with the pan (Pan only no seal) and without and see no difference other than the motor wants to stall when I click neutral with the pan on. I am suspicous that there is air turbulance causing the MPH loss and the stalling deal on top end. (unless ironically other problems have cropped up that I am not seeing ie electrical or motor)
I am going to try my next race to seal off the scoop with the pan a huge piece of foam and see if that makes a difference. Any suggestions or comments would be appreciated.
BTW the new scoop is open in the back and the old one was closed.
Drew Wonderly
SST 159
SST159 is online now   Reply With Quote
