Old 05-02-2012, 07:32 AM   #30
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: Iron Dukes??
The Iron Duke (also called the 2500, 151, Pontiac 2.5, Cross Flow, and Tech IV, though the decal on the air filter assemblies actually reads "4 Tech") was a 2.5 L (150.8 cu in) I4 piston engine. All Iron Dukes were built by Pontiac beginning in 1977 and ending in 1993. After this time, the GM 2.2 L OHV 4-cylinder replaced it across the entire lineup of vehicles that offered it.
This 151 was also used by American Motors (AMC) starting in 1980, as the base engine option in the RWD Spirit and Concord, and continuing in both cars through 1982. The AWD (4x4) Eagle carried the 151 as standard equipment for 1981, and carried it midway through the 1983 model year. It was also available (as the Hurricane) in economy model Jeep CJs. AMC replaced the Iron Duke 2.5L I4 with a 150cid Inline-4 of their own, derived from their evergreen sixes.
The Iron Duke is often confused with Chevrolet's Stovebolt-derived 153 from the 1960s Chevy II, but the engines are entirely different - the Iron Duke's intake manifold is on the passenger side, as opposed to the driver side.
Applications:
More written here...
https://en.wikipedia.org/wiki/GM_Iron_Duke_engine
This info is not correct if my memory is any good......The first year Pontiac engines had both intake and exhaust manifolds on the same side of the engine.....drivers side.
The following year the new and improved cross flow head was on that engine. Thats how I recall it and I worked in a Pontiac dealer and worked on those cars regularly.
GM was producing some real junk and as a line mechanic I got to work on all sorts of engineering marvels......
This was the era of "corporate engines under the hood". Engines were calibrated so lean they could barely get out the driveway sometimes without bucking and missing......and my personal favorite....the odd fire Buick V6 3.8....shook so bad they had to add counterweights and soft engine and trans mounts.
I have some very funny stories from my days working on these cars and what we did to try and diagnose and fix some of these cars.
It was a Pontiac-Jeep-Subaru dealership and I worked on them all as an A Tech....
Rich Biebel
S/C 1479
Stock 147R
