#1 | |
Jack, you are correct. There HAS been a buzz surrounding Class Racing that is almost never seen/heard, other than for the Hemi Shootouts. That said, like Bruce asked, "How has this helped the majority of S/SS racers?". And, IMO, it hasn't. -Has it brought in a large group of new racers to the class? No. Most (most) of the people racing the new CJ and DP cars were already racing in S/SS. David Barton, Bo Kenney, Irvin Johns, Eric Merryfield, to name just a few. Sure, we've had a few people either new, or returning after long layoffs (Don Fezell, Charlie Fitzsimmons, to name two), but in the grand scheme of things, it hasn't done much to increase car counts in S/SS. And, when you factor in the fact that many current Stock racers have scaled back, or quit, racing, the gain is minimal, to no gain at all. And, to further discuss the point of the buzz, I don't see that the hype/media exposure has brought in any new sponsors or anything to Class Racing (has anyone here gained a sponsor because "They [the sponsor] want to get in on this class racing deal, it looks exciting"?) No real huge benefit to the MAJORITY of S/SS racers. A boost to the ego's of a few, and general disdain, headaches and disapointment to many. -The horsepower factors are 'catching up'. Yes...to a point. Not nearly fast enough for most of us. Case in point--the 5.7 liter DragPak. Started out at the factory 305 rating. The first race it hit the track, June 2010, two people (Merryfield and Roy Johnson) both went more than -1.20 (more than -1.50 under the old Index) under in F/SA, and hit it. At Bristol, a slow, hot, altitude track in more than 3,500' corrected altitude 1 1883 F/SA Eric Merryfield, Andover MA, '09 Challenger10.586 11.85 -1.264 2 2216 F/SA Roy Johnson, Greenville TN, '09 Challenger 10.630 11.85 -1.220 This combination received a hit for that race. Fast forward just over a year later, late June 2011. By then, the 5.7 had been hit up to 404 (a ninety-nine HP increase in about 54 weeks). As a side note to the above F/SA runs, to this day, there aren't many, if ANY, F/SA that can run a 10.6 in even the best Atco air. 1 5035 A/SA Keith Lynch, Greenville OH, '10 Challenger 9.929 11.00 -1.071 I think this helps prove the point. That, while the AHFS may indeed be working to a point, it isn't near enough, or fast enough. With the new-for-2011 rule that, 'the faster you go, the more HP you get', it may help over time. BUT, if NHRA would have had the foresight, people in charge who were smart enough and cared enough, this all could have been solved before it started. Case in point, a comparison between the late 1970's 360 Mopar engine in a Volare/Aspen, and a modern Mopar 360 in a DragPak: The 5.9 360 cid Mopar engine in the late 1970's Aspen/Volare's is rated 289, by NHRA. A fast one of these will run 11.1's to 11.20's in H/SA (Jim Wahl in Florida has one). Now, compare Jeff Tueton's 2009 5.9 360 in a DragPak, with every advantage you could want over the old cars/engines. It has a 1000 cfm throttle body, better, plastic intake, better flowing heads, .490" roller cam, and has run 10.52 in G/SA, while running at H weight , and was rated at the time at 275!!!. NHRA should have looked at the specs and realized that a FAR superior engine should NOT be rated FOURTEEN HP LESS!!! And oh yeah, Jeff's DP at the time got to weigh one hundred and fifty four (154) pounds LESS than Jim's Aspen. Can you say "bring a tank to a water pistol fight"? NHRA, in my opinion, should have looked at the specs and started the new cars at a fairer rating. Using the above info, instead of 275, they could have started the modern 360 at, say, 300, 310, 325, whatever. THAT, in itself, would have been a big deal...trying to level the playing field from the get-go. Again, just my humble, respectful opinion. Yes, the older cars are catching up, slowly. Assuming no new CJ/DP/Copo combos are built after 2012, and we have just the current available engines, they might catch up almost, almost, totally, in a few years. -Fezell's run. Yes, it's fast. Yes, it's historic. And, while many do not place this as large of an accomplishment as Bobby D and Jim Waldo's feats, it definately has it's place in history.
Mike Carr, Tri-State S/SS Association President Looking for 2015 S/SS Race Sponsors Contact me if interested buffdaddy_1302@hotmail.com (724) 510-5912 |
NHRA actually have avoided this whole transgression with one or two simple lines in the Rulebook:
"If you could not buy the car, as is, and license it, register it, insure it, and drive it home, it is not a Stocker, it is S/S only". Like the Race Hemi's, AMX, Thunderbolts, etc.
#3 | |
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
#4 | |
I tend to agree as well, but I can appreciate both sides. The addition of these cars is not much different that when NHRA combined SS and Modified. However, all of the modified cars have their own classes.... as it should be in Stock. In support of that, look at comp. Turbo charged cars have their own classes as do the supercharged cars. All of the stockers could run in the eliminator against each other fairly but the the new "order from a menu" cars should not be combined in the same classes with "real" OEM stockers. There is no factor or equation that will ever make them the same.
Scott Wilcox 2193 3x National Champion SS/A, SS/B, SS/K, SS/L, SS/AM, A/SM, C/SM, B/A, C/A, G/A, H/A |
#5 | |
Banned
Bruce is correct on this and as far as Jack he's just wearing his NHRA cheer leader outfit! A lot of fan love the old cars as the can relate to them.
Ralph Quote:
#6 | |
And don't be jealous of my cheer leader outfit .....I'll never be able to thank Toby enough ! ! !
Jack Matyas 1547 FS/C 2015 Camaro COPO # 62- 2012 Camaro Convertible COPO |
Liked 405 Times in 158 Posts
So when a 1500hp, 3.0L twin turbo/supercharged/4 valve per cyl/ etc/ etc 2020 Ford outruns a 1968 hemi...your going to bitch again?
Perhaps we should outlaw everything but hemi's and 69 camaro's? If the new camaro ever gets here I wonder how much bitching and whining there will be then? Why in hell do you think the camaro is even being built???? It's not because of obama's love for cars!!! No I'm not a nhra fanboy, but c'mon guys, this ain't 1970 anymore. Everyone thought the world was coming to an end with fuel inj, and then the ls or lt or whatever camaro's...but technology moved on. |
Liked 32 Times in 19 Posts
All the "firsts" are great.All the new cars are great except the resorting to power adders. Had they all been just injected or carbs it might not have been so lobsided. NHRA as done nothing new or different. They have always tended to turn a blind eye to anything new and hope the new cars replace the Nostalgia Stockers and Super Stockers. The problem is the racers with the cars are the victims only when the resist the trend. Sad but many have thought their time and money invested in the older cars would last forever. Times change and NHRA doesnt. Life after class racing is fine.
Liked 460 Times in 91 Posts
And don't be jealous of my cheer leader outfit .....I'll never be able to thank Toby enough ! ! ![/QUOTE]
Jack the next time you wear it please shave your legs it would look better. ![]()
Bob Bender 144 O/SA 2010-2012 National Record Holder |
I sometimes wonder what the Flathead guys said when the Smallblock Chevy was introduced !
Dave Ley |
