Go Back   CLASS RACER FORUM > Class Racer Tech > Garage Tech
Old 04-14-2012, 01:56 PM   #1
Marine One
Marine One's Avatar
Default Re: Shop air compressor lines
I have about 75 feet of sched 40 PVC (2.5" diam) in my shop. It has been there for 10+ years without incident. I regulate the pressure to about 105 psi. Use good stuff, put some drop legs in with drain valves, etc.
Like everything - Proper prior planning prevents piss poor performance. Learned that in the Corps
Chad Sheets | STK 319 | 10.69 | 1.39
Marine One is offline   Reply With Quote
Old 07-12-2012, 10:58 AM   #2
Harry 6674
There is not a worst material to use for compressed air then pvc. The stuff will hold shop air pressures but it doesn't take much of an impact to rupture like a gernade. Shrapnel everywhere. I know this for a fact. Use something else. Copper,steel,aluminum,dot air line anything but pvc. There are pvc like air rated pipe but it is very expensive and uses a special glue. The stuff we use where I work is blue. Its called dura-pipe.
Harry 6674 is offline   Reply With Quote
Old 07-17-2012, 03:44 PM   #3
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
I wouldn't use anything but copper, myself. It can't be more expensive than the "snap together" aluminum stuff, can it? You only need 1/2", or maybe 3/4" if you're running it a long ways. The going rate for 1/2" (wholesale) is less than $2 a foot right now. It won't rust or break, and it makes the job look like you know what you're doing instead of Legos...I may be biased, though, since I'm in the mechanical piping biz.
Paul Merolla is offline   Reply With Quote
Old 07-17-2012, 05:31 PM   #4
Greg Hill
Liked 279 Times in 68 Posts
Several years ago when I built my shop I bought an Ingersoll Rand compressor. They had a deal that they gave you so much aluminum tubing and compression fittings with the purchase. I ended up buying enough to do my whole shop which is about 3400 sq. ft.. That stuff has worked great and been trouble free.
Greg Hill 4171 STK
Old 07-18-2012, 09:31 AM   #5
Jeff Teuton
Liked 325 Times in 50 Posts
We have copper in all our buildings, with shut down valves at various places. No failure in the pipe, but the couplers/hoses give up every so often. Also have automatic drains on each compressor, and drains on all drops on most lines where room allows. I hate to think how much metal we have at today's prices.
Jeff Teuton 4022 STK
