Old 04-12-2012, 10:26 PM   #1
slwryde
slwryde's Avatar
Default Re: gear or converter
like you
slwryde is offline   Reply With Quote
Old 04-13-2012, 12:22 AM   #2
Geerhead55
Liked 5 Times in 5 Posts
Angry Re: gear or converter
Originally Posted by slwryde View Post
like you
WTF does that mean, Greg? This guys trying to help you and you bash him. Your motor is light on compression,, your camshaft is on the small side for a stroker small block, your converter is a little tight, and you come on here asking for help and you blow somebody off when they respond to your question. So much for getting any help here, I'm thinking.
Good luck with your project which ever way you decide to go.
Danny Durham
Old 04-13-2012, 08:51 AM   #3
slwryde
slwryde's Avatar
Danny Durham
It means take the time to explain yourself...like you did. Your input is helpful. You think the camshaft is small for a stroker small block. 1320 said it had to much duration. Also you think the converter is to tight.
Another guy said a three speed might be best.
The engine makes good power and torque despite the low compression. Its easier to change gears and converters than camshafts and compression.
So which would benefit most gears or the converter?
Old 04-13-2012, 11:55 AM   #4
Phillip marvetz
Phillip marvetz's Avatar
Lower 1st gear would be my choice. What RPM are you running thru the traps and is it where you want it to be?
2009 V/SA Record Holder
Old 04-13-2012, 12:34 PM   #5
slwryde
slwryde's Avatar
I am turning 6900 rpm. I could probably afford to turn it a little higher say 7500 rpm.
Old 04-13-2012, 01:42 PM   #6
Steve Hayward
Aside from addressing larger tasks in that combo......... It would cost nothing to borrow some smaller carbs and see if that helps............
Steve Hayward is offline   Reply With Quote
Old 04-16-2012, 03:35 AM   #7
Phillip marvetz
You could go another 1000 on the stall rpm. Changing to a lower 1st will mask that a bit also. The carb is to small for a 414 cu engine tuning 7000rpm also.
