Old 03-30-2012, 12:20 PM   #1
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Cool 10 Tie down straps and axle strap recomendations?
Please feel free to chime in on the good, the bad and the ugly.
The growing fleet has caused me to take a rather hard look at the Jegs 10K axle straps and rachet assemblies, they seem to be wearing out a bit quick for my taste.
I have some Mac's axle straps that are really nice.
Just got some Gforce strap and axle combos, which are pretty nice, but I am not really sold on them. I have had gforce stuff in the past.
What do you all use?
Anyone use towing company grade Vulcan stuff?
Thanks
Eric
Eric Merryfield 1883 STK
Old 03-30-2012, 12:37 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: 10 Tie down straps and axle strap recomendations?
S-Line Tie down straps(3,333 lbs. working load limit) rated 10,000 lb. capacity
http://www.s-line.com/index.html
Used the Jegs combo straps for many years without issue.
Old 03-30-2012, 12:44 PM   #3
Andrew Hill
Andrew Hill's Avatar
Liked 170 Times in 38 Posts
We use Mac's tie downs, and they are the best. Tons of people have problems with the car coming loose in the top of a stacker, but the straps on ours are as tight after hundreds of miles as they are at the beginning. Plus, they pay contingency.
3207 D/SA, C/ED
Andrew Hill is offline   Reply With Quote
Old 03-30-2012, 02:19 PM   #4
Greg Hill
Liked 279 Times in 68 Posts
What Andrew said.
Greg Hill 4171 STK
Old 03-30-2012, 03:35 PM   #5
CycloneFE
CycloneFE's Avatar
Liked 2 Times in 2 Posts
I will echo what the Hill's say, Mac's is the best. I broke down and bought a set last year and have only used them several times, but they seem just like new. I have tried all of the other cheapies from the farm stores, harbor freight, chain and binders, and I think I am staying with Mac's.
Steve Jackson
Old 03-30-2012, 07:16 PM   #6
Roberts Motorsports
I have used the Mac's straps and they are excellent. Also, the Vulcan Professional grade are very good too. Vulcan Pro also has some unique specialty tie downs that work very well in the out of the ordinary applications.
Roberts Motorsports is offline   Reply With Quote
Old 03-31-2012, 12:10 PM   #7
Philip Saran
Liked 14 Times in 11 Posts
Me too............I've been using mine for 3 years.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 03-31-2012, 12:42 PM   #8
1320racer
1320racer's Avatar
All I know is Mac's look exactly like my S-Line tie downs.
Old 03-31-2012, 05:29 PM   #9
DIAPERMAN
Liked 21 Times in 6 Posts
You get what you pay for!!! Buy made in USA
DIAPERMAN is offline   Reply With Quote
Old 04-01-2012, 07:25 AM   #10
Greg Barsamian
Liked 410 Times in 94 Posts
Look at Allstar Performance part # ALL 10188, (Summit sells them)
It's the "direct hook" model that incorporates the snap-hook at the point of the ratchet so you don't have to crawl under the car to "tighten the strap down". They're made in the USA by M&R products (formally in NJ) and packaged for Allstar......I'd also suggest using axle straps w/Delta rings & sleeves, they're offered by M&R as well.
Check out M&R (http://mrproducts.com/)
If you prefer cheaper "knock-off'" straps, The Stafford Springs Swap meet is coming up on April 15th.
BTW, The new RV & trailer look awesome going up Rt 495,
