DaVinci Dominator carburetors, 1 pair, for gasoline, used on 2x4 sbc application - $2000
MGP #SB1400 aluminum connecting rods. 6.000 length, 2.000 rod journal, 0.927 wrist pin, new - $700 BME pistons for 12deg. SBC. 1 set of 10, forging #66mg F, 4.183 bore, 1.330 c.h., 2.750 x 0.927 pin, double spirolox, double upper oilers, keyway slots, 3mm oil ring groove, blob dome, top and 2nd ring grooves not machined, pin bores not honed, un-touched since purchased, new - $800 GM cast iron bowtie block #10051183. 8.890 deck height, 4.183 bore, 350 main, priority main oiling, 0.927 Jesel keyway lifter bushings located for 15deg gm heads, 55mm coated Jesel cam bearings, 4 bolt billet steel main caps, splayed caps 3 positions, race-ready, unused since honed and decked. - $3000 15 deg. Chevrolet heads. complete with 2.200./1.600 Manley ti. valves, 2.100 triple springs, l.w. Manley ti. retainers, 10 deg locks, lash caps, spring cups. zero runs since freshened. - $3500 MGP aluminum connecting rods. 5.850 length, 2.000 rod journal, 0.927 wrist pin, bronze bushings @ pin - used. $200 P.P.P.C. Casidiam coated steel wrist pins. 0.992 dia. x 2.750 lg. x 0.150 taper wall. 135 gram. 1 set of 8. new. $300. Cola sbc crank, 3.200 stroke, 2.000 rod, 350 main, knife-edged, o.d.?d, rod pins drilled, used. $750. Precision Crankshaft Grinding sbc crank, GM forging, 3.250 stroke, 2.000 rod, -0.010 350 main, knife-edged, o.d.?d, nitrided, polished, used. $500. Crankshaft Specialties sbc crank, 3.100 stroke, 2.000 rod, 350 main, chromed, o.d.?d, rod pins drilled, used. $500. Manley super 7 deg locks #13080. 5/16? steel, standard height, slightly used. Manley 7 deg titanium retainers, triple spring, slightly used. Del West 7 deg titanium locks, 5/16?, used. Del West 7 deg light weight titanium retainer, triple spring, #565-LTW. Callies crank snout stud #CPPI-013G, 6? lg, 7/16?NF - 7/16?NF. $10 MSD pro power coil, used. $50 MSD pro power coil #8220, used. $50 Peterson fuel regulator, used. McClintic vacuum regulator. $25 Moroso inline scavenge oil filter - new. $35 Holley (Oberg style) oil filter - new. Stef oil filter adapter #6740 - $35 Harwood #3157 dragster air scoop. $150 Spitzer Aero dragster air scoop. $200 Moroso BBC valve cover gaskets #93040 - new. $30 Comp valve springs #911-16. BBC, 1.525 o.d. w/damper, 125#@1.900, 300#@1.400, 1.200 coil bind, used approximately 100 miles in dually 454 engine. $45 Comp BBC exhaust spring spacers #4779. 0.300 thk, set of 16. $40 Comp 3/8? dia. Lash caps #622-16 - new. $30 Comp 5/16? steel super locks #610-16 - new. Mallory Promaster coil #. $50 2 Holley fuel pressure regulators. $25 Strange 5/8? x 3? long steel screw in wheel stud kit, new. $50 1 gearset for Liberty 5 speed trans. 2.74-1.99-1.54-1.24-1.00 ratio - used. 9? Ford Pro-Gear, 5.14:1 ratio, used. $150 9? Ford Pro-Gear, 5.00:1 ratio, lightened, used. $125 9? Ford Pro-Gear, 5.00:1 ratio, lightened, used 1 run. $225 also have other miscellaneous sbc and dragster parts for sale. photos available upon request. Chris Bozic Comp1892@msn.com 412.767.5562 412.427.6183 |
