Liked 984 Times in 198 Posts
Wax and Grease remover works best for removing the glue.
Liked 317 Times in 103 Posts
A more fun way of removing decals is with your fingernails. If after repeated attempts, and a few beverages, they don't come off, it is easier to just buy another car. Another tip form beyond common sense.
Ron Ortiz U/SA goo gone
Ron Ortiz 2102 STK |
#3 | |
Liked 189 Times in 48 Posts
Thanks to all for the tips - gonna give it another try today
Angelo DiTocco '98 Firebird SS/HA '98 Firebird B/SA |
Liked 94 Times in 24 Posts
Hair dryer or heat gun. Just finished taking them off the Cuda. Painfully long, just put some tunes on and take your time. Tar and bug remover works ok for excess glue.
George Fitzpatrick 426 HEMI STK, SS |
PATIENCE and any of the above methods combined in any form.
Oh, and PATIENCE!!!!!!! Gasoline will cut glue as well as any of the other methods mentioned. |
Liked 359 Times in 103 Posts
I was told to try Easy Off Oven cleaner and I was a little afraid of the paint on the car being damaged.
However, I tried it and it works pretty well. You must rubber gloves but it did not damage the paint at all. It is also much easier and faster than WD-40. You will need a good supply of soft rags or soft shop paper towels. I used it and it works. My 2 Cents Rick Cates |
Liked 126 Times in 20 Posts
The hair dryer then a coat of Goo Gone from Magic American Products,Bedford Heights,Oh. Then plenty of elbow grease. Seems to be more comming off of cars than going on these days. That trick of getting clothing lint on the sticky side of the new decal does work well.
Tim Worner SS 1747 |
#8 | |
Liked 427 Times in 97 Posts
Test a small spot on whatever surface your trying to remove the decals on! Nick tried to remove "painted lettering" from a trailer, the oven cleaner not only removed the lettering but the paint from the panel as well...... Oven cleaners will streak and dull the finish if left to penetrate for a long period of time! |
Liked 451 Times in 77 Posts
Liked 216 Times in 77 Posts
Napa sells the plastic razor blades and they work great along with a little heat.
