Liked 544 Times in 213 Posts
Tommy I am old but still pretty spry as you well know......
Who else my age rides a bike for hours on end when racing NHRA events.....Nobody thats who......LOL I loved Superman.....The dude squished the rock and made a diamond and put in some statue to keep the natives happy......Well thats how I remember it anyway...... ..... I Might run the S/C series this year.....Matt's workin on me...I feel the need for speed......LOL See ya soon my friend.....Rich
And if they glaze the rings from too much idling/low load time, a little bon-ami down the intake will rescuff the rings and cylinder walls. Used to be supplied by Caterpillar with a part number. Also a long time ago.
Bon Ami was supposedly used in the early to mid 60's on Pontiac motors in dealerships that had some ring seal problems. Add some to the oil....run it for a while and than change it. They might have been using chrome rings.
Was a little before my time but some guys told me about it at a Pontac dealer I worked at in the '70's as a line mechanic....
Liked 419 Times in 85 Posts
Is there a way to prevent this carbon build up in this design of generator? should you run it out of gas when you shut it off?
Liked 43 Times in 29 Posts
Hey Paul from all the research I've done this it seems to be a common occurence. What I've read, running the generator as often as possible under a load will lessen the possibility of carbon build up. If you are running down the road in the motor home have the generator running with a load applied, such as the microwave oven, for a period of time. I can say this that after I removed the heads to clean the carbon build up the generator runs smoother than it ever did before and with much less noise.
Mark Ruset 2048 STK |
There is really no way to prevent this issue. Onan recommends decarbonizing the engine as a regular maintenace service. Myabe they thought using 4C cleaner would help and I am sure it would but running it is what cuases the carbon buildup. They run at one speed 1800 Plus or Minus about 50-100rpm no matter what the load is...or at least they should if the governor and engine are working well.
The only way to prevent the carbon buildup, is to not run it so that makes no sense.... Maybe some fuel additives might help.....but mostly they are snake oils to me for the most part. I can tell you without a doubt that since these engines are air cooled. The hotter they get the more they coke up the oil and prodcue more residue buildup. The higher the load you have on the unit.....the hotter they will get....So reduce your loads in hotter weather and make sure it gets a good supply of fresh air away from it's own heated exhaust air. I just took a part some newer style over head valve single cylinder units. They are 4000watt units that run at 3600rpm. 4KY is the model and they are very popular .....One had a lot of isssues...burned exhaust valve.....lots of carbon....bad oil rings......2700 hours and was running poor for a long time and run hard....The oil ring was allowing a ton of oil in the chamber and basically caused all the problems......I think it was run so hot early in it's life it killed the oil ring expanders tension. So here was another unit killed by heat.....It was mounted under the back end of a van and I have worked on many of those. They are always in bad shape......Air flow!!!! Mobile Dog Groomer van.....They get used every day and those generators get a ton of hours.
