New never used GM Rocket block 9.025 deck rough bored to 4.125. Machined for Jesel dogbone lifters. Sat around and has surface rust but is fine.
New Lunati Pro Series crank 4.0 stroke for 6.0 rod JE Pistons: Part #110994 Brand new in box never used description as follows: Were going to be used in a 15 degree sbc Application: 350/400 Small Block Brodix -12 Dome Bore 4.125/Stroke 4.000/Rod Lgth 6.000 Ring Set J10008-4125-5 Description: Standard -12 Dome C/H: 1.000 Comp Ratio 52cc: 15.8 55cc: 15.1 60cc: 14.1 Dome Vol: 2 (Solid dome design) Grms: 456 *JE's traditional piston. *Excellent for Sprint Car use. *Smooth flow domes for optimum flame travel. *Valve reliefs will accommodate oversized valves and high lift cams. *.927 x 2.750 (130g) 51s series wrist pins included. *Pin fitting and double spiral locks included. *Precision CNC machined ring grooves, accepts 1/16, 1/16, 3/16 rings. *Fits 3.480 and 3.500 stroke. New Comp Cams Roller big block journals .699 intake .660 exhaust 318 in dur 329 exh dur 112 centerline Sell complete and local to NJ $3000 robertirvin@optonline.net |
$2800 cash and carry....NJ only
