Liked 2 Times in 2 Posts
What do you use for air lines in the shop, like a permanent wall mounted line? I have seen systems that press and slip fit and claim 300 to 400 burst psi. If plastic is used, is it tough to "straighten" out and look good or does it wave a lot? Would black pipe be best? What does the racer say?
Steve Jackson |
Liked 1,937 Times in 582 Posts
Schedule 40 pvc will do what you want. Available at any home improvement or harware store.
Mike Pearson 2485 SS |
Liked 216 Times in 77 Posts
The problem with PVC is not that it can fail its what happens if it does fail. Go over to the Eastwood shop talk site and search "PVC air lines are deadly" for a story of what can happen. For the record mine has steel pipe in it. A little more expensive and a little more time to install but one less thing for me to worry about.
I have done some "googling" and found a lot more. Plastic and PVC probably just fine for average air stuff, but if you want to really move some air for some heavy tools or blasting, the required PSI may cause failure in the plastic. The iron pipe has been warned of rust, but isn't that what you have drain valves for? Copper has a major cost factor, and I know as I have just finished putting my plumbing in using copper.
I guess the air line looks like a nice early summer project. Feel free to add any more ideas or situations you have, I like listening to people who really do this sort of thing.
Steve Jackson |
Liked 348 Times in 152 Posts
Just plumbed my shop over the holidays, used white PVC, looks and works just fine. Yes, kinda low air usage and only run about 95lbs. line pressure. Very pleased.
Phil Molski PMR Performance S/C 1623 |
There is also schedule 80 pvc pipe available. It is quite a bit thicker and has a higher pressure rating. This is available at most plumbing supply dealers. Schedule 80 pvc is a dark gray color. This would be a great choice for higher pressure applications.
Hey Steve,
I can't believe I missed this thread, anyway I just upgrade my air lines. I have been meaning to finish my shop and never seem to find the time. I used the RapidAir system. It was very easy to install, but you will have to lay the tubing out in the sun to get it to straighten out. In can be tough to get a straight look. Fortunately I ran mine behind the walls. I think for the money its is an excellent product, made in the USA. The have many different kits available for higher pressure. The system I used is rated 150 psi, more than enough for what I use it for. There are other systems that are similar, but are made in china, and the quality is not there. I'm not a big fan of black pipe, I don't like the look, but it is the most economical. |
Thanks Ken and all who have posted, there is so much more than I even dreamed about. I am going to look harder at what and where I place my stuff before deciding. I do appreciate ALL who have had a comment and still appreciate any more in the future.
Steve Jackson |
I have about 75 feet of sched 40 PVC (2.5" diam) in my shop. It has been there for 10+ years without incident. I regulate the pressure to about 105 psi. Use good stuff, put some drop legs in with drain valves, etc.
Like everything - Proper prior planning prevents piss poor performance. Learned that in the Corps ![]()
Chad Sheets | STK 319 | 10.69 | 1.39 |
There is not a worst material to use for compressed air then pvc. The stuff will hold shop air pressures but it doesn't take much of an impact to rupture like a gernade. Shrapnel everywhere. I know this for a fact. Use something else. Copper,steel,aluminum,dot air line anything but pvc. There are pvc like air rated pipe but it is very expensive and uses a special glue. The stuff we use where I work is blue. Its called dura-pipe.
