#1 | |
Liked 1,833 Times in 416 Posts
Alan Roehrich 212A G/S |
SECTION 10A: STOCK CARS, ENGINE:1, ROCKERS ARMS (Page 5) (1/19/2012)
"OEM or a Aftermarket rocker arm permitted. Either adjustable push rods or adjustable OEM rocker arms permitted on any application, but not both. Needle/roller bearing pivots and roller tips are permitted for all applications. Must remain same design as original application (i.e. stud mount must retain stud mount, pedestal type must retain pedestal type and shaft type must retain shaft type. Stud girdles prohibited.) Stamped steel OEM and OEM-type rocker arms may be reinforced." .
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
Liked 7 Times in 7 Posts
All good points by everybody here...With all the trouble...almost makes you want to yearn for the old days...the real STOCK Eliminator...(lift-duration-overlap-spring pressure...and REAL stock rockers!)
Liked 325 Times in 50 Posts
How about this. Make sure your rockers are the same configuration like the book says. Make sure the ratio stamped on the rocker is the same as the 'blueprint specs', and make sure your cam passes with a solid or blocked lifter. What am I missing here.
Jeff Teuton 4022 STK |
#5 | |
Liked 6 Times in 4 Posts
Forget the ratio stamped on the rockers. Those numbers evidently mean nothing. Be sure to measure the lift at the retainer AND at the lifter so you can do the math when you check the ratio of the rocker arms yourself. What should be a simple bolt-on is turning out to be a real cluster that no one ever expected.
Remember...watch what you wish for, it might just come true!!!!! |
I think it's a real cluster for those that still ask to go to the bathroom...
Jeff Lee 7494 D/S '70 AMX |
#8 | |
Either adjustable pushrods or adjustable OEM rocker arms permitted on any application, but not both. Does that mean that part of the rule no longer applies?
Jeff Interlicchia 7077 D/SA 1998 Pontiac Firebird LT1 J707 E/T 1966 Dodge Coronet 500 |
They threw me out last year for having 1.65 rockers and the spec said 1.60. The cam passed. Up to yall. I got 1.60's on the car now.
Jeff, I thought that was just to keep you from getting horsepower!
Jerry Did they really check or just see what was on the rocker? |
