Banned
Liked 235 Times in 110 Posts
Correct-A-Mondo............Alan is 1000% correct......brush up on your stocker racing history. Remember the Crane stamped steel rocker that came in 1.6 for the small block chevys. Several big name stocker racers were DQ'ed many years ago by NHRA for using these even though the lift checked correct at the retainer. It changes the rate of lift and produces more flow as the valve rises off the seat. Its DUMB to even think you could use rocker ratios greater than what the engine spec. book calls for. Stop trying to reinvent the wheel.
[QUOTE=X-TECH MAN;305163 Remember the Crane stamped steel rocker that came in 1.6 for the small block chevys. Several big name stocker racers were DQ'ed many years ago by NHRA for using these even though the lift checked correct at the retainer.[/QUOTE]
How does NHRA check rocker ratio at teardown? |
Liked 2 Times in 2 Posts
I don't know how NHRA does it but I would think the easiest and most accurate way would be cam lift divided by valve lift.
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
Banned
Thats backwards.......divide the lobe lift into the valve lift. The number you get is the R.R. Ifs its over then your DQ'ed. There is a couple of ways to get it.
Liked 705 Times in 219 Posts
Seems that the last several posts have verified what I wrote in my post on page 2. We need to look at some absolutes- two sources of absolutes come to mind- those provided by the engine designers, and those mandated by the sanctioning body.
Absolute #1-- Valve lift must be OEM or as specified. Absolute #2-Rocker arm ratio must not exceed OEM. Cam lobe lift isn't too well specified. In order for #1 above to be achieved in a desireable fashion,#2 has to be followed as well. In the case of a small block Chevrolet,ideal results are when valve lift is half again lobe lift.In the event lobe lift is correct,and valve lift is lacking, then another means has to be employed to achieve it. That is where push rod length comes into play. Now, you don't really want exact specs here, you want to be safe by .005-.010". This is because the tech guy at teardown might not read mikes the same way I do. Also, expansion due to heat might cause results to vary. If my intake lift spec is.390". I would love to see an actual.379-.382".Now, if I achieve this spec with a very long pushrod, I'm getting the maximum extra duration and rate of lift out of that valve train. Now, the other booby trap has to be recognized. If you checked lobe lift, it passed right on the number, used a very close to optimum, a long push rod, you could still result in a rocker ratio that is a bit over, however,that couldn't help but make the valve lift over as well.Optimally, a cam lobe with the correct lift, a valve with lift good by .008-.010, and a rocker arm ratio of 1.47-1.49 would be the best of all worlds. Now, good luck getting it! |
#6 | |
Banned
#7 | |
