Old 01-21-2012, 03:35 PM   #1
TOM KASCH
Liked 241 Times in 100 Posts
Cool ideas for a big block chevy engine
My friend wants to build a new engine for his street rod.
ASked me about a 454 Econo engine, sleeved & destroked engine ?.
Any ideas ?
Going in a street rod.
What would be good set of heads, etc.?
Have anything for sale ? He Lives in Calif...
Old 01-21-2012, 10:44 PM   #2
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Wink Re: ideas for a big block chevy engine
obvious one
348 Chevy, .060" over, with a 409 crank !
Good cam and valve train, this intake:
HEE HEE !
ID:	10449   Click image for larger version
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 01-22-2012, 04:26 PM   #3
Greg Reimer 7376
Liked 719 Times in 220 Posts
Default Re: ideas for a big block chevy engine
Originally Posted by Aubrey N Bruneau View Post
obvious one
HEE HEE !
348 with an .060"over bore, and a 3 3/4" stroke.408"cu.in. That intake would make all the difference in the world.Ultimate W motor would be a 452 or so inch 409, a set of Lamar Walden Z-11 heads, and a dual four barrel intale built along those lines. The two plane intakes were horrible on those engines.
Old 01-23-2012, 02:54 PM   #4
Michael Kilduff
Any ideas ?
He could probably find a 366 Tall Deck truck BBC for cheap. The money saved from sleeving and destroking a 454 would certainly cover the costs for longer pushrods, distributor, and intake manifold required on the Tall Deck engines. Plus the 366/427 Dump Truck motors are 4 bolt main, usually steel cranks, and are a touch wider in physical dimensions to give an appearance that they are 'bigger', the street rod guys usually like that.
IHRA STK 932 O/SA
Michael Kilduff is offline   Reply With Quote
Old 01-23-2012, 03:49 PM   #5
What is a 454 econo engine, sleeved and destroked? Not sure I follow, or understand the question.
Old 01-28-2012, 11:12 AM   #6
rawhide
Liked 7 Times in 5 Posts
Sounds like a 396 to me.
Roland
rawhide is offline   Reply With Quote
