Old 12-31-2011, 09:57 PM   #1
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Default Onan Generator Carbon Knock
I believe I have developed a carbon knock in my Onan Emerald 4000 generator. Has anyone else had a similiar experience and if so is there an easy remedy?
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 01-01-2012, 09:33 AM   #2
Chuck Westcott
Chuck Westcott's Avatar
Smile Re: Onan Generator Carbon Knock
Onan makes a carbon remover in a spray can I believe. I remember removing the heads on a 4.0 and scraping the carbon off. Ran like new.That was a pain for sure.
Chuck Westcott- S/C -S/G 225
Chuck Westcott is offline   Reply With Quote
Old 01-01-2012, 12:25 PM   #3
Dave Tincher
Default Re: Onan Generator Carbon Knock
You wont have much luck with the carbon spray. Its more for maintanance, Removing the head is a pain but its the only real fix.
Dave Tincher 306 SS
Dave Tincher is offline   Reply With Quote
Old 01-01-2012, 02:03 PM   #4
DIAPERMAN
Liked 21 Times in 6 Posts
Talking Re: Onan Generator Carbon Knock
After you fix if you run some Lucas fuel treatment in every few tanks of gas this will help.I have a lot of rv buddies that swear by it. Just an idea
DIAPERMAN is offline   Reply With Quote
Old 01-01-2012, 02:27 PM   #5
Mark Ruset
Mark Ruset's Avatar
I was hoping that I wouldn't have to pull the head, however that seems the concensous. I thought there may be a way to inject throught the intake some sort of liquid to breakup the carbon, like GM Top Engine Cleaner.
Mark Ruset 2048 STK
Old 01-01-2012, 05:49 PM   #6
Dave Steltz
Dave Steltz's Avatar
Mark I had the same thing with my previous MH...tried a few different spays, gas treatments...didnt work...Had to pull the generator out and pull the heads off...PIA for sure...also I dunno if you can do it in the MH, it was easier for me just to pull it out....
Dave Steltz 135G SG/SP/SST
BIAECH Racing Team
Dave Steltz is offline   Reply With Quote
Old 01-02-2012, 04:09 PM   #7
brett3533
brett3533's Avatar
Liked 41 Times in 13 Posts
Mark, You might try some sea foam from napa. Start gen, and pour it into carb and stall out the gen. Alloy to set for between 20 and 30 minutes then restart. It will smoke alot but may loosen up and clean out your carbon deposits.
Brett McFarland
A/S
brett3533 is offline   Reply With Quote
Old 01-02-2012, 05:24 PM   #8
dennis dunlap
Mark ,I,ve used the GM upper cyl lube for many years ,worked for us. Sprayed it in an let it set , i used a long flexable hose to get in further.
Spin it over spray, let it set, repeat .I always had the headgaskets but never did pull the heads .Running generater with no load on it seems to be the enimey.....
dennis dunlap is offline   Reply With Quote
Old 01-02-2012, 07:59 PM   #9
Mark Ruset
Mark Ruset's Avatar
Thanks to all who replied, I'm going to try the GM Top Engine Cleaner. I let you all know how it went
Mark Ruset 2048 STK
Old 01-03-2012, 10:24 PM   #10
Darrin Christen
Darrin Christen's Avatar
I had the same problem. I thought is was a bad rod bearing or broken piston. When I took the heads off I found a smashed chunk of carbon on top of one of the pistons. I probably could have sprayed something through the spark plug hole to dissolve it but I already had the generator out and apart. I would try some carbon cleaner before taking it apart. You can try a marine dealer who sells outboard engines. They carry several different types of carbon cleaners you spray into the engine while running.
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
