Buick sitting on stands waiting for Virginia next yr, Just need a new helmet and window net. Just under 200 passes, get 1 more season out of this JA Performance prepped piece. I hope.
Putting the finishing touches on my 8.50 index car which cant go 8.50 yet.
Gary Federico S/St, S/G 1814 |
Jason, if you would just park in the right neighborhood you would not have to pray to God for such a petty thing.
Rock, would you install an anti roll in my roadster? I dont mean you like personally, I would be sceard to drive after an elec wiz welded on it. By the way your car is as fast as a 632 now anyway.
Jeff Beckman 318J ET, SG 318T SC |
Liked 882 Times in 236 Posts
After I get done with all the winter work on my customers rides,I may have time to freshen up my Vette and find a few more mph with a new converter from Eddie Select.
I might even get some time to work on the old Willys . Got a 482" Rodek to go in and a lot of parts to make it "street legal". Want to make it a street driven B/Gas 8.60 index car. Hey Gary wanna run Heads Up !!!
Liked 4 Times in 2 Posts
Its not a problem Jeff....My partner is one of those can do it all..kind of guys...
Rewiring the rat's nest in the S/ST car with a new kit from K&R, and replacing a stock decklid with a nice fiberglass bolt-on piece.
Fixing the bent frame in the S/G car that I stood on the bumper during bracket-mode testing in Nov. Then upgrading the trans and hoping I can hit a .370 tree with a 2850# car. |
Putting a crank trigger on it (kinda tricky as the F.I. pump is mounted there also) upgradeing to a coil that's compatable with my MSD grid controller.Sending the belts back for rewebbing/recert. Buying a new helmet (that snell 2000's got to go!) Sending the converter in for inspection/stall change.Building a double dump valve body for the spare transmission.
Bill Baer 3391 SC, 339B SC, QR |
Im finally going to put a glide in my pontiac and putting new hoosiers and new fuel pump on the jr
scott fifield |
#8 | |
Way cheaper and quicker than using individual components.
I just wired a 69 amx using the k&r wiring kit and pro cube and thats a really nice setup,great job kevin
scott fifield |
Adding 10 feet to the car!!! Well, actually building a new one...yes I will be driving a new 2011 Dragster this upcoming year with a 605" motor......can someone explain this chasing concept to me? And by the way, what does a race in front or beside you look like anyway?????
Will start season in G-ville with the altered though.... And yes Beckman, you can turn this one........
Ron Finney 396V S/C |
