Old 12-10-2011, 04:58 PM   #1
danny waters sr
danny waters sr's Avatar
Thumbs up Re: All major event s/ss winners undrgo tech inspection
I think you should have your engine sealed when entering a race.
Once engine is sealed the seal cannot be removed without a tear-down, except for a carb change and the carb should be inspected at this time and re-sealed.
As far as the engine seal goes ,once it is sealed it can be checked at random for any given race and should be told this. If seal has been broken before actual tear-down then it is considered to have been illegal in the first place and should be DQ'd on the spot.
The DQ time will be determined on how many races was run before actual tear-down.
If you know your engine is legal then you should not have a problem with this system.
If you want to make changes before you have been torn down then you still must go through tear=down. Say you went to 4 races before you actually got torn down and you were foung illegal, then the penalty should be 4 races and then come back and torn down before you race and get a diff (certain) color seal showing you have been torn down,.
Also let that seal be good for the rest of the season.
In IHRA ,we have gone to the engine builder's shops and checked engines. After engine was approved it was sealed on the spot and was good for the current year.And has to be torn down again for the next year......Kind of like a chassis cert,but a little diff.
Old 12-10-2011, 05:38 PM   #2
Chad Rhodes
Default Re: All major event s/ss winners undrgo tech inspection
I have had my engine sealed within the last year, forget where, probably the sports nationals. If you are saying to paint the carb, intake, and a head bolt, that's not a bad idea
Chad Rhodes 2113 I/SA
Old 12-10-2011, 05:48 PM   #3
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
I like the way IHRA does teardown now before record run,that way car is making record attempt it has already been verified it's legal.
If I was wanting to be sure I had all legal field of cars I would change to all cars had to be verified legal before being allowed to race,then seal engine and as long as seal is'nt broken you're good.
Mike Taylor
Old 12-10-2011, 08:41 PM   #4
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Mike Taylor
I have done this for the last two years. It sure is nice to be able to go to a race and be able to win or set a record and already have the tear down out of the way! I plan on doing it again this January. It also makes for happier tech guys if they know they don't have to tear you down! Jim
Old 12-10-2011, 06:07 PM   #5
fredjohnston
Liked 55 Times in 14 Posts
What happens when someone freshens up their motor or changes engines during the year???? This breaks the seal or in the case of an engine change, shows up with no seal at all.
fredjohnston is offline   Reply With Quote
Old 12-10-2011, 06:20 PM   #6
danny waters sr
Talking Re: All major event s/ss winners undrgo tech inspection
In those cases the engine should be checked before freshening to prove it was legal .
If you know you are to freshen it then have it checked before you freshen it.(you are going to tear it down anyway) , so do it at the track before you leave....
I know there will be diff situations as always.
These are just ideas anyway and some are good and some are debatable....at any rate it is better than doing nothing...and everyone has a sealed engine from the start knowing it could be torn down at any time and punished if wrong.
Old 12-10-2011, 06:29 PM   #7
NewHemi
NewHemi's Avatar
The way schedules are set up for most Stock and Super Stock races is that there is no time before the races to tear down.
We tore down before the record run attemp in Las Vegas because the way that race is set up, we weren't scheduled to run until very late in the day instead of the usual 8:00 am call to the lanes at every other race.
But more teardowns are indeed needed. We had one car that beat us for class, was running illegal, determined much later, and didnt get torn down at that race. That same car, running an illegal engine, got us several horsepower hits too.
David
The New Hemi Guy
NewHemi is offline   Reply With Quote
Old 12-10-2011, 07:31 PM   #8
Jody Lang
Liked 92 Times in 29 Posts
Is "seal" a real deterrent?
Couldn't anyone carry their own "seal" to do touch ups if needed?
Jody Lang is offline   Reply With Quote
Old 12-10-2011, 07:56 PM   #9
Danny Ashley
Liked 110 Times in 29 Posts
I had a customer that asked me to build him a "Qualifying" Q-Jet to which I said no. I said,"If you did have one, what would happen if you got sealed?" He told me he found out the manufacturer of the sealant that NHRA uses and ordered every color. Someone is always going to find a way.
Danny Ashley is offline   Reply With Quote
Old 12-10-2011, 08:35 PM   #10
danny waters sr
You are right Danny.
That is why rules are made ,so they can be broke or bent especially bent!!!!!...
Now days there are not enough tech guys t o perform these duties.
I used to go with Kenny Koonce Sr back in the day and they did a lot more tear-downs then than now,and you never knew when it was your turn ,fast or not......Ahhhhh the good ole days....
