Old 12-10-2011, 02:48 PM   #1
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
Default Re: All major event s/ss winners undrgo tech inspection
Chad I think you are on to something.. but I agree with Billy, the cheaters will simply stay out of the top 10. Why don't they go back to at the very least putting that cool orange paint on your carburetor like they did when I was a kid? Also, maybe NHRA could go out and find some retired racers who know the ins and outs of the old combos?
'65 Mustang SS/L & L/SA
Old 12-10-2011, 10:30 PM   #2
winstonindy
Guest
Posts: n/a
Originally Posted by Mark Ruset View Post
You ain't going to stop cheating so don't beat your head against a wall. What needs to be done is enforce the safety rules. I can tell you from my own experience, that the last time an NHRA Tech guy asked me to place my transmission in gear and attempt to start the engine was back in 2007 at Bradenton. I wonder how many cars are lacking the neutral safety switches. Safety right now is what we should concern ourselves about.
I obviously didnt tech your car this year.
I asked every driver this year to do this at the races I worked tech. Many said I was the FIRST to ever ask them to do that. Some guys looked at me like I was joking. Several almost flatout refused. Many thanked me for being thorough. Even sent a few back to the trailer because the neutral safety didnt work. Since I work tech AND safety I might look at things differently.
Old 12-11-2011, 02:28 PM   #3
Byron Worner
Liked 37 Times in 7 Posts
Originally Posted by Chad Rhodes View Post
Here is what I would do. Remember, we are looking for the flagrant cheaters, not the guy with .004 too much lift, with these inspections.
1. Impound top 10 after qualifying.
2. Everyone pulls carb,a spark plug, and a valve cover.
3. NHRA acquires an inspection camera that can go down an intake runner or through a spark plug hole.
4. A visual inspection of carb, casting number check on heads, visual on intake.
5. Stick camera down a few runners, looking for obvious modifications, Ti valves, etc.
6. Stick camera in spark plug hole to verify piston configuration
7. do an approximate valve lift check on stockers using a pair of calipers (not terribly accurate, but if someone has a BOGUS cam, its going to be WAY bigger not .015)
All of the above could be done at the scales, and then seal the motors. If there is anything odd in this cursory inspection, it would not be grounds for immediate DQ, just grounds for a full teardown.
Another possibility would be requiring an inspection plug in the pan that the camera would fit through, just to look for AL rods or ultralight pistons.
I like this idea but instead of top 10 qualifiers this should be done for, but not limited to, Class winners, heads up run winners, bottom 10 qualifiers (people could cheat to run under the index) and any run a second under or a run that gets automatic horsepower.
Byron Worner is offline   Reply With Quote
Old 12-11-2011, 02:41 PM   #4
jmcarter
jmcarter's Avatar
Liked 3,227 Times in 981 Posts
Originally Posted by Byron Worner View Post
....and any run a second under or a run that gets automatic horsepower.
The CJ guys and tech would get awfully tired if that was the case...a whole lotta work! Face it folks, NHRA is not going to tear down any more than they have to, they will be cutting staff before they add any.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 12-11-2011, 08:51 PM   #5
boster
boster's Avatar
Billy , left that out by accident . Everyone put a dial on there car.
Bo Kenney
boster is offline   Reply With Quote
Old 12-11-2011, 09:32 PM   #6
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
I think you hit the nail on on the head, Jim.
Bob Don 128 SS
Old 12-12-2011, 01:47 PM   #7
Tony Janes
This is the right answer This subject has been through the winter season quite a few times.Except it as it is.
Tony Janes 7941 STK, SS
Old 12-11-2011, 09:20 PM   #8
Chad Rhodes
i could agree with that
Chad Rhodes 2113 I/SA
