Old 12-06-2011, 01:43 PM   #1
Nitro Joe Jackson
Nitro Joe Jackson's Avatar
Liked 67 Times in 19 Posts
Default Re: Wally Parks editorial from Dec 1955
speaking of tear downs, i remember the days everybody was torn down after winning class and after you won your eliminator you was torn down in staging lanes after pictures where taken, i still remember Max Hurley coming over, taking a beer out of our cooler and looking at my father and the IHRA tech man grinning and saying, "Hope she is just a little big" after we won the Empire Nationals, lol we was good to go.
Nitro Joe Jackson STK 3431
nitrojoe@neo.rr.com
Old 12-07-2011, 03:29 PM   #2
Jim Parsons
Liked 195 Times in 30 Posts
What's to come of all this dishonesty? Well, there are several possible solutions. One is to discontinue the running of Stock classes, but this isn't practical. Another might be to run Stocks for "time only," giving no awards to winners. Last, but not least, would be to change class restrictions to simply require "no visible modifications," leaving hidden parts wide open to alteration.
Travis,
Thanks for the editorial, well written as always by Wally and at the time sincerely having the best interest of the sportsman Stock racer at heart.
However I’m not sure I’m getting the point of this post, is Glendora considering some changes to Stock eliminator? I.e. “discontinuing the Stock classes” or perhaps “no visible modifications” making it stock appearing leaving hidden parts open to alteration.
Just call me paranoid but with all that’s going on with opening up the rules away from true stock I feel justified in my concern.
Or is about the tech personnel being under appreciated? As far as the tech personnel I know I have tremendous respect for them and the sincerity. From what I hear underappreciated and under compensated is more an issue with their employer these days than from the racers. I guess another affirmation of the tech personnel’s committed sincerity and respect for class racing.
If Wally was around these days what would he be writing about stock eliminator and tech?
Thanks and Regards
Jim
Jim Parsons is offline   Reply With Quote
Old 12-08-2011, 09:22 AM   #3
Casey Miles
Liked 507 Times in 92 Posts
If I knew how to post a picture, I'd post a 1956 Merc with the 2 x 4 tea pot carb engine that was in my friends shop not too long ago.
Casey Miles
248H Stock?
Old 12-08-2011, 02:20 PM   #4
Fred Holdorf
1956 Ford and Merc 312 cu in, 2 x 4 were rated at 260 HP. 56 Ford/Merc 312 single quad was rated 225/230 HP. Also NASCAR Ford's ran "tea pot"carbs but Merc's had option of Carter WCFB's. Popular cheater trick was to use bigger Cadillac Eldorado carbs for 5 to10 HP advantage. 57 Ford had 2, 2 x 4 combinations 270 HP with small cam and 285 with big cam, both 312 Cu In. I've never seen factory assy. line built 2 x 4 292 cu in cars, but alot of wierd combo's could be built if you knew someone!
Fred Holdorf is offline   Reply With Quote
Old 12-08-2011, 03:06 PM   #5
BlueOval Ralph
Banned
The dealer paper I have shows tea pot Holleys, Mercury did use the Carter Wcfb's on the 1957 M-335 which was the 368 Lincoln engine used in the Mercurys Bill Strope built the engines for them there is a article in Hot Rod 1957 on the M-335s
BlueOval Ralph is offline   Reply With Quote
Old 12-08-2011, 07:55 PM   #6
Fred Holdorf
I stand corrected as I found a picture of the 260 HP Merc engine in Hot Rod (May 1956) and they are definetly Holley's. Article was on Speedweeks at Daytona Beach. I guess my memory isn't what it used to be. Regards, Fred
Old 12-08-2011, 09:08 PM   #7
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 307 Times in 103 Posts
I can't speak for Travis,but I took his post as how much somethings are still the same now as they were in 1955.
I thought it was neat to read article.
Mike Taylor 3601
Old 12-08-2011, 09:21 PM   #8
james schaechter
Liked 1,435 Times in 299 Posts
Casey Miles
248H Stock?
Here it is Casey.
James Schaechter 3163 STK
Old 12-10-2011, 01:05 AM   #9
Dean3870
Whats STOCK about stock eliminator any more any way? with all the valve train rules, light weight parts. 2 steps, metric tranys in cars that they did not come with. The hundreds of pounds of weight shoved behind the rear tires. Some one please answer the question! this is not what the class was made for. you can tell me a 4000 lb car with a 283 that has a 1.70 60ft should pull the tires 2 foot in the air. Not that any one cares what i think, nor would i expect you to. no one cares about the little guy trying to get into stock, or the guys that have suported the sport for the last 40 years that dont have the health and or the money to throw at the cars like every one else. you just want the indexs lowered to run them out! great idea! I think every one needs to take a step back and remember what stock eliminator was supose to be, Now its just super stock on a 9 inch tire. Well i said what i had to.
Mike Dean
3870
Dean3870 is offline   Reply With Quote
Old 12-21-2011, 01:27 AM   #10
treessavoy
Liked 4 Times in 4 Posts
Mike,
You are right, back in the day a Stocker was stock. I remember a race at Atco where a Stock ' 50 Studebaker was disqualified because he had a non-stock muffler on his car.
When I left the country for my Southeast Asian vacation in 1969 the class record for SS/CA was low 11's if memory serves.
There will always be people that will push the rules, some that will cheat and others that will play within the rules and the HRA's will continue to amend rules to help Speed Equipment manufactor's make more money and appease some racer's need for more speed.
JimR
Jim Rountree
