Old 11-28-2011, 01:44 AM   #1
Phillip marvetz
Phillip marvetz's Avatar
Default Re: 2-Step with a Stick Shift ONLY please !!!!!
Put a switch on the shifter that over rides the two step. Probably will be where you have your line lock switch now.
2009 V/SA Record Holder
Old 11-28-2011, 09:58 AM   #2
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Brake pressure switch on a stick shift car helps you be consistent. When you stage the car, find through experimentation what is the minimum safe brake line pressure necessary to hold the car still while staged. Then the release time of the brake system becomes a consistent factor in the "leaving event". The more pressure you build into the brake system, the longer it takes to release it.
Since you currently do not have a line lock, the brake pressure switch is not an issue, unless you have three feet.
