Old 05-15-2007, 02:10 AM   #6
Jeff Lee
Guest
Posts: n/a
Default
Here's my cheap lite-weight solution. They make a special size (I forgot the group number) for Honda Civics. Tell them you have a 1992 Civic. No more than $58.00 depending if you get the standard or premium model. Buy two. Charge both the night before. Use one for qualifying then change it out for eliminations. You can charge the 1st battery and if you make it to the 4th round, rotate the battery. Besides being cheap, they weigh only 15 pounds each. I never had one problem in Stock with my 390 engine and constantly forgetting to turn the water pump or fan off while in the pits.
NHRA #7494 SS/H
1970 AMC AMX
"Best Appearing" @ NHRA '06 Pacific Sports Nationals
JeffLeeAzRealty@Qwest.net
602-418-9797
